Results 1 to 12 of 16
Plumbing & Plumbers Forum - Best way to fix a rad to a tiled plasterboard wall?
Discuss Best way to fix a rad to a tiled plasterboard wall? in the Central Heating Forum at Plumbers Forums; I go to loads of radiators at work that have fallen off the wall due to the installing thinking it is ok to install a 1100 x 500 double panel ...
    Top Plumbing Forum Contributor arran197's Avatar
    Aug 2011
    Wolverhampton
    723
    Default Best way to fix a rad to a tiled plasterboard wall?
    I go to loads of radiators at work that have fallen off the wall due to the installing thinking it is ok to install a 1100 x 500 double panel radiator with 2 plasterboard fixings per bracket.
    Anyway, last night I went to my fiance's aunty's house because the radiator was leaking. The rad has a small hole in the bottom, so I will need to fit a new one. But the old one just has a 2" 10 and a brown plug in the plaster board, which I don't really want to do. But the wall is tiled, so it is going to be difficult to use expansion screws and red heads are not going to work either. I am thinking I'm going to have to drill out the tile to the size of the head of the expansion fittings.
    What are your thoughts/experiences/suggestions?
    Jan 2011
    MOLD, N Wales
    276
    Default Re: Best way to fix a rad to a tiled plasterboard wall?
    Try these with No10 Screws, never had a problem yet.http://www.*************/p/fischer-p...k-of-100/58219 or if you reallwant the belt and barces use these.http://www.*************/c/screws-na...hors/cat840108
    Jan 2011
    MOLD, N Wales
    276
    Poofix by the way.
    Aug 2011
    Wolverhampton
    723
    Sorry Ian, the links don't work?
    Jan 2011
    MOLD, N Wales
    276
    Did you substitute ********* with screwfix? ??
    Ayrshire
    301
    I always get a good fixing to tiles with brown plugs and 2" 10's.
    If you are worried about getting a good fixing silicone the back of the bracket. Once it sets it will never come off
    Aug 2011
    Wolverhampton
    723
    Quote Originally Posted by Ian10261 View Post
    Erm, no. Will try that. How come you **** it out?
    Aug 2011
    Wolverhampton
    723
    Just been looking at those Fischer plasterboard fixings, they look like they might do the job. The other ones are the ones I would normally use, but the problem is that the tiles won't allow the part showing to fix in the plasterboard. So I need something to fit in the wall.
    Jan 2011
    MOLD, N Wales
    276
    I did'nt *** it out, for some reason its done automatically when you post a link. The hollow wall anchors can be used on tiled walls but you need to snip off the two pointy bits that would normally dig into the plasterboard and they're best put in with the special tool http://www.*************/p/rawlplug-setting-tool/92462 i think you know what to do now.
    Aug 2011
    Wolverhampton
    723
    Ha ha, ye cheers Ian. A guy I work with has got one of the puller things. Might be worth me investing in one I suppose as turning the screw heads is a bit of a ball ache! Lol! I did fancy giving those plugs a go, not used them before and the reviews of them seem quite good. But they are nearly £7 and I will only use about 8! Lol!
    Do you buy a lot of stuff from screfix Ian? I am thinking of getting the rad from there too, £28. Do they put the height or width measurement first?
    Jan 2011
    MOLD, N Wales
    276
    it's probably worth buying yourself a box of em, i always do as its not just rads they come in handy for. I tend to shop around for my stuff and sometimes Screwfix fits the bill. Yes i've had rads from them but will generally collect them from the local depot which is only 15 mins away, had too many bad experiences with damaged mail order rads.
    east london
    6,738
    ive always found these to work well just remember to get the bracket up the right way before you push them in
    http://www.*************/p/fischer-s...ck-of-20/89787
  1. how to deal with the tiled wall?
    By bluesky in forum Plumbing Forum
    Last Post: 19-05-2011, 12:14 AM
  2. Fixing Basin and Bog To Tiled Wall & Floor Help Please
    By mmmadman in forum Sanitary Ware
    Last Post: 25-11-2010, 07:55 AM
  3. Plasterboard in builders opening ?
    By BLOD in forum Gas Safe Register Forum - Public Forum
    Last Post: 13-11-2010, 10:58 PM
  4. hanging new boiler on plasterboard
    By Gascat in forum Gas Safe Register Forum - Public Forum
    Last Post: 29-08-2010, 01:35 PM
fixing radiator to tiled plasterboard
tiled plasterboard fixings
fixing a radiator to tiled wall
fixing to tiled plasterboard
fixing to a tiled plasterboard wall
fixing radiator to plasterboard wall
fixing to tiles on plasterboard
