Results 1 to 4 of 4
Plumbing & Plumbers Forum - Baxi Combi 105HE LPG Regulator?
Discuss Baxi Combi 105HE LPG Regulator? in the Central Heating Forum at Plumbers Forums; I have had a 105HE fitted to run on LPG (Propane), having swapped the jet bar and changed the dip switch setting on the control board, everything works fine except ...
    Sep 2011
    Default Baxi Combi 105HE LPG Regulator?
    I have had a 105HE fitted to run on LPG (Propane), having swapped the jet bar and changed the dip switch setting on the control board, everything works fine except that it appears that I have bought the wrong gas regulator on the bottle. This is a holiday home and therefore the heating/water is not used much so the LPG is via a gas bottle as a tank in the garden is a fortune.
    The regulator I bought appears to be of the sort for camping and "low" flow applications and so when the boiler burners ignite I believe the flow is too high and so the regulator thinks there is a leak and shuts off? By holding in the overide boiler everything works fine.
    The regulator is marked 1.5 kg/hour 37mbar.
    Can anyone advise on what type of regulator is required? and where I might get one?
    Alternatively what is the maximum gas flow rate into the boiler when running LPG and I can source the correct item.
    Michael
    Gray0689's Avatar
    Jun 2010
    Northern Ireland
    4,654
    Default
    Who fitted this boiler and regulator ???
  3. GSR? Want gas safety or boiler repair advice? We will check out that you're genuine via the gas safe website, so please dont be offended when we ask for your details. DIYers, odd job people and have a go heroes need not apply.
    Jun 2010
    698
    Default Re: Baxi Combi 105HE LPG Regulator?
    Gas Safe registered for LPG ?
    SimonJohns's Avatar
    Bridgend, Wales
    3,609
    Default
    Quote Originally Posted by aggis View Post
    I wouldn't if said so lol
    "nothing is impossible"
  1. Baxi 105HE
    By rich201283 in forum Central Heating Forum
    Last Post: 02-07-2011, 01:27 PM
  2. BAXI 105HE Combi - Minor Leak on Heating Flow Pipe (out)
    By MisterGriffiths in forum Central Heating Forum
    Last Post: 20-03-2011, 05:28 PM
  3. Baxi Combi 105HE - CH Problem
    By lizzyf in forum Central Heating Forum
    Last Post: 21-12-2010, 09:11 PM
  4. baxi 105he
    By andyg0507 in forum Gas Safe Register Forum - Public Forum
    Last Post: 18-08-2010, 07:36 PM
lpg regulator for boiler
how to convert baxi 105 to lpg
what kind of regulator to run lpg combi boiler
lpg regulators for boilers
what regulator d o need for an lpg boiler
baxi lpg boiler what regulator
baxi safety gas regulator
