Plumbing & Plumbers Forum - Worcester 26/32 lifting capacity
Discuss Worcester 26/32 lifting capacity in the Central Heating Forum at Plumbers Forums; I need to re-site my existing fuel tank which is currently gravity fed, my new site will mean that the bottom of my oil tank will be approximately one metre ...-
03-09-2011 #1New to Plumbing Forum
- Sep 2011
I need to re-site my existing fuel tank which is currently gravity fed, my new site will mean that the bottom of my oil tank will be approximately one metre below my boiler pump. Will my boiler be able to cope with lifting the oil this height and if so how do i get the oil to reach the pump initially with the height difference? My boiler is a Worcester Danesmoor 26/32.
03-09-2011 #2Plumbers Arms member
- Feb 2011
- The Land Of The Prince Bishops
- 7,223
- 284
- Thanked 691 Times in 681 Posts
Re: Worcester 26/32 lifting capacity
It should cope.
03-09-2011 #3UK Plumbersforums Trusted Advisor.
- Jun 2010
- Northern Ireland
- 4,664
- 65
- Thanked 432 Times in 419 Posts
You will need a tiger loop fitted
cylinder capacity
By phijoe in forum Plumbing ForumReplies: 3Last Post: 04-03-2011, 02:54 PM -
Hot water cylinder capacity
By Harpmatic in forum Plumbing ForumReplies: 4Last Post: 16-12-2010, 05:52 PM -
Extra hw capacity
By billybongo in forum Plumbing ForumReplies: 5Last Post: 13-01-2010, 12:04 AM -
Choice of boiler capacity
By Tall Question in forum Central Heating ForumReplies: 10Last Post: 28-11-2009, 02:39 PM -
advice needed lifting floorboards / plywood
By andyb in forum Plumbing ForumReplies: 15Last Post: 25-09-2009, 08:42 PM
Freebie Alert - Black Mamba - the...
3 Minutes Ago in Plumbing Forum
