Results 1 to 11 of 11
Plumbing & Plumbers Forum - trianco solid fuel boiler leak
Discuss trianco solid fuel boiler leak in the Central Heating Forum at Plumbers Forums; Hi. hope some one can advise, i have a trianco solid fuel (antrohcite) boiler. about 20 years old there is water in the cinder tray at the bottom at first ...-
28-08-2011 #1New to Plumbing Forum
- Aug 2011
- 7
Hi.
there is water in the cinder tray at the bottom at first i thought it was rain coming down the chiminey but upon investigating this it could not be. could it be possible i have a leak inside the boiler ?????.
any advice would be great is the boiler beyond repair how much to repair etc.
i;m a wood butcher as you heating engineers would say so i have a little knowledge.
28-08-2011 #2UK Plumbersforums Trusted Advisor.
- Jun 2010
- Northern Ireland
- 4,870
- 76
- Thanked 447 Times in 434 Posts
Sounds like it's done mate
28-08-2011 #3UK Plumbersforums Trusted Advisor.
- Mar 2010
- lincolnshire
- 3,740
- 298
- Thanked 375 Times in 358 Posts
Re: trianco solid fuel boiler leak
sounds like time for a replacement
28-08-2011 #4New to Plumbing Forum
- Aug 2011
- 7
28-08-2011 #5UK Plumbersforums Trusted Advisor.
- Mar 2010
- lincolnshire
- 3,740
- 298
Try Dunsley Oxypic, follow the instructions, it does work
The Following User Says Thank You to ecowarm For This Useful Post:
joiner wayne (28-08-2011)
28-08-2011 #6New to Plumbing Forum
- Aug 2011
- 7
thank you its worth a try for the sake of £25 if not then a new system might be called for
Again thanks for your help
28-08-2011 #7New to Plumbing Forum
- Aug 2011
- 7
28-08-2011 #8UK Plumbersforums Trusted Advisor.
- Jun 2010
- Northern Ireland
- 4,870
- 76
29-08-2011 #9UK Plumbersforums Trusted Advisor.
- Mar 2010
- lincolnshire
- 3,740
- 298
Oxypic is the best for boiler leaks but you must follow instructions
29-08-2011 #10UK Plumbersforums Trusted Advisor.
- Jan 2008
- North Yorkshire
- 4,155
Think of it not as a repair but as only as giving you some breathing space to plan and budget for a new boiler.
29-08-2011 #11Plumbers Arms member
- Oct 2008
- oxfordshire
- 1,872
- 477
- Thanked 183 Times in 142 Posts
I know Trianco went bust last year but I suspect that there back up and running so you could try them for a new heat exchanger Trianco
if its not dangerous Im not doing it
Blocked Flue Vents Solid Fuel Boiler (Trianco TRG45)
By dom_trig in forum Central Heating ForumReplies: 0Last Post: 23-08-2011, 11:50 AM -
Solid fuel boiler installation
By furryneddy in forum Plumbing ForumReplies: 5Last Post: 29-05-2011, 10:57 AM -
By furryneddy in forum Plumbing ForumReplies: 0Last Post: 27-05-2011, 10:35 AM -
solid fuel back boiler
By mjt in forum Plumbing ForumReplies: 4Last Post: 26-04-2011, 08:13 PM -
Trianco TRG 45 Eurostar Solid Fuel.
By Jazz Head in forum Central Heating ForumReplies: 15Last Post: 14-11-2010, 11:30 AM
Heating on upstairs when it is ...
5 Minutes Ago in Oil and Solid Fuel Forum
