Page 1 of 3 123 LastLast
Results 1 to 12 of 29
Plumbing & Plumbers Forum - Ideal HE24 Boiler Central Heating Problem
Discuss Ideal HE24 Boiler Central Heating Problem in the Central Heating Forum at Plumbers Forums; Hi Guys I am not a plumber I'm a sparky, I have a Ideal HE24 Boiler with a Central heating problem, the central heating won't start the Domestic water is ...
    Aug 2011
    14
    Default Ideal HE24 Boiler Central Heating Problem
    Hi Guys
    I have a Ideal HE24 Boiler with a Central heating problem, the central heating won't start the Domestic water is fine no problem what's so ever.
    I have trawled the forum sites on the net looking for a fix for this fault and found it to be a common occurrence with this boiler but no definite answer to fix it.
    My problem starts the same as many others do. The letter 'C' for “central heating” appears in the window but the light just flashes and fails to ignite the boiler. BUT the domestic water heats when called for with no problem.
    I have been lucky to have had access to some new spares for this boiler so have eliminated a few faults which the manual suggests.
    I started with all the common faults first Batteries, room thermostats, timers, by passed thermostat shorting out in boiler, Changed thermistors flow and return and overheat thermostat. Circulating Pump is Free, New diverter valve fitted, Tried brand new out of box PCB, Still no Joy.
    Whats the next thought
    May 2011
    county durham
    443
    Default Re: Ideal HE24 Boiler Central Heating Problem
    ideal what ? i'd be able to help you if i knew what the inside of the boiler looked like
    Aug 2011
    14
    Ideal Isar he24
    armourer's Avatar
    Jun 2011
    Midlands
    541
    Im guessing its an Isar HE24 and my next guess would be to stop throwing parts at it and get a heating engineer in.
    1,407
    One of the worst boilers ever made, get a gas engineer or one of ideals engineers out. It could be anything on this boiler.
    Aug 2011
    14
    Bye gum mikie lad that didn't tek long foh they to be defeated ya not a boxer lad ya can't throw towel in that easy, get told thinking cap on
    diamondgas's Avatar
    Newcastle Upon tyne
    6,116
    jimmymak, what colour is the water when you bleed a radiator?
    Swapping parts willy-nilly sorts jack! But costs a bit unless you know someone... But then if you know someone you wouldn't be here! lol
    Aug 2011
    14
    Diamondgas, what colour is the water when you bleed a radiator?
    It's crystal clear
    diamondgas's Avatar
    Newcastle Upon tyne
    6,116
    Did you change the whole diverter or just the head? It sounds like the valve is stuck in the hot water position! If not that then check the isolation valves are open and all your radiators are turned on! Sounds like heat isn't leaving the boiler yeh?
    Aug 2011
    14
    I changed the complete diverter although the old one was OK. Yep all is in order valves open etc.
    The water does leave the boiler but this was not heated by the central heating mode.
    When the boiler heats the domestic and no further call for hot water from the tap is required and if the central heating thermostat calls for heating the now body of hot water heated from the domestic call is released into the central heating system by means of the Diverter valve.
    Aug 2011
    14
    When changing over from domestic mode to central heating the boiler shuts down after domestic call taps not extracted the boiler then changes to CH Mode the boiler then seems to start to fire up but this is for a 2-3 second period then shuts down. hope this is of any help
    diamondgas's Avatar
    Newcastle Upon tyne
    6,116
    Quote Originally Posted by jimmymak View Post
    And you're saying at this point the 'c' continues to flash and there's no attempt of ignition .... just to clarify yeh? Next step I'd be doing is linking out all external controls on the main plug under the boiler L1-L2 to eliminate external controls! If you know for definite the diverter spindle is moving out and the boiler isn't igniting I'd be inclined towards the user control stat
  1. Problem with Ideal Isar HE24
    By Rafal Staska in forum Central Heating Forum
    Last Post: 23-01-2011, 12:55 AM
  2. Ideal ISAR HE24 problem
    By mrredwood in forum Central Heating Forum
    Last Post: 22-12-2010, 08:24 PM
  3. can i turn off DHW and use just for Central Heating Ideal ISAR HE24
    By JUNIOR_no1 in forum Central Heating Forum
    Last Post: 28-11-2010, 07:55 PM
ideal boiler no central heating
ideal he24
ideal isar he24 no central heating
ideal isar boiler no central heating
boiler problems no central heatingproblems with ideal gas central heating boilersideal istor boiler problems
