Results 1 to 12 of 19
Plumbing & Plumbers Forum - unvented system
unvented system
Discuss unvented system in the Central Heating Forum at Plumbers Forums; punter has leaking cylinder,y plan,heated by oil boiler, he wants to change it for an unvented cylinder indirect ,he wants it in the attic and along to gable end about ...
    May 2009
    nb b
    1,603
    Default unvented system
    punter has leaking cylinder,y plan,heated by oil boiler, he wants to change it for an unvented cylinder indirect ,he wants it in the attic and along to gable end about 5 and a bit meters any thoughts would be appreciated and a idea regarding the price range thankyou.
    N.I
    149
    Default Re: unvented system
    Main concerns i would have would be freezing in winter and having adequate pressure for the system, also be careful existing pipes and joints are upto increase in pressure if it an old system, also ensure you are able to get your discharge pipe out, but if positioned beside gable shouldn't be a problem. Personally i'd be looking to be in and out in a day, so a days labour plus materials, plus a wee mark up
    N.I
    149
    don't forget your spark either
    AWheating's Avatar
    WestMidlands
    6,042
    its going to have to be altered to a s plan, the biggest changes apart from the move will be the discharge pipework and the alterations to cold supply. You will need to construct a heavy dutie tank stand and a walk way and loft light for yearly service and maintenece. Your sparks will have to rewire to s plan and also if needed move or add an immersion circuit. also everything will need lagging with 19mm-25mm lagging and whatever the cylinder manufacturers recommend for frost protection.
    labour probably 2 days,sparks cost, over heads, profit, materials.
    btw im commercial,
    NOT.
    unguided1's Avatar
    Oct 2008
    oxfordshire
    1,872
    Also you need to look at the loading for the roof joists if it is a large unvented cylinder, also you need to consider how your going to insulate the cylinder in the roof space
    if its not dangerous Im not doing it
    N.I
    149
    It can be installed on a y plan saving alot of hassle and expense, the oso and rm models can be anyways.
    AWheating's Avatar
    WestMidlands
    6,042
    Quote Originally Posted by gmac View Post
    how do they get around not having a zone valve to comply with the requirements of g3?
    btw im commercial,
    NOT.
    May 2009
    nb b
    1,603
    what do you mean regarding adequate pressure for system, this is a sealed system,your a fast worker in and out in a day,not me mate at least two full days,maybe even a third to commission.
    May 2009
    nb b
    1,603
    does the mid position not give enough control to comply , or do you have to zone each area were required.i do not fully understand what your saying can you please elaborate, thanks
    N.I
    149
    Here's a link to oso installation instructions, page 11 or 12. http://www.oso-ho****er.co.uk/uk/pdf...ion_manual.pdf
    The savings could be the difference between getting the job and not getting the job and the spark might even say thankyou lol
    N.I
    149
    Quote Originally Posted by desrob View Post
    You're unvented is working off your mains supply, so if you have a low pressure mains supply, say 1bar, then it defeats the purpose of installing an unvented really, the better the mains supply to your cylinder, the better pressure out of your unvented, plus you'll be looking for a 22mm mains supply to your unvented,
    When I say a day I'm looking at a nice smooth running job with no problems and my bitch boy bein on site, Without seeing the job it hard to give an accurate time scale, then again smooth running jobs are getting harder to come by.
    AWheating's Avatar
    WestMidlands
    6,042
    yes the mid position cant be used for an unvented cylinder, you have to have a valve that is normally closed under fault/off conditions to protect from over heating the cylinder. if i remember with an unvented cylinder you require a min of 3 thermostatic controls, one of which must be a manual resetting lock out.
    btw im commercial,
    NOT.
  1. new rad on unvented system
    By mickqc in forum Plumbing Forum
    Last Post: 14-04-2011, 06:29 PM
  2. Unvented system
    By vodex in forum Central Heating Forum
    Last Post: 11-05-2010, 02:44 PM
  3. Unvented system
    By lenny in forum Central Heating Forum
    Last Post: 06-09-2009, 11:31 PM
  4. Unvented system ...No hot water...
    By RayPlumb in forum Plumbing Forum
    Last Post: 24-06-2009, 10:45 AM
  5. Unvented heating system
    By Cristoff in forum Central Heating Forum
    Last Post: 17-05-2009, 11:00 PM
ukplumbersforums.co.uk rm cylinders forum
