Results 1 to 9 of 9
Plumbing & Plumbers Forum - Ideal Classic FF350 problem
Discuss Ideal Classic FF350 problem in the Central Heating Forum at Plumbers Forums; Hi guys, got a problem that could do with your help..... I drained down a system to add a rad, the boiler is an ideal classic ff350. When filled system ...
    Feb 2009
    49
    Default Ideal Classic FF350 problem
    I drained down a system to add a rad, the boiler is an ideal classic ff350. When filled system back up, the boiler now cuts out after firing up for about a minute. I have replaced the zone valves too so and I know they work ok.
    I know there is little information out there for fault finding as this boiler is very basic. Would the overheat stat not be working even tho boiler before was fine.....
    Any help would be greatly appreciated.....
    Ta, frankief
    May 2009
    7,303
    Default Re: Ideal Classic FF350 problem
    Take it you have not been inside the boiler to dislodge anything therefore would go fora circulation problem,check pump ok then air lock,make sure any manual finger vents have been opened,any on pipework above boiler?
    leave system running,it may clear after a few hours or you could blast through with a bit of mains pressure
    imho
    Kev the gas's Avatar
    West Sussex
    600
    air lock probably, how was the water when it drained down?
    As Puddle stated a blast of mains water through can work wonders.
    Bullet proof boilers, were my favourite for years, knocked spots of the Suprima.
    Kev.
    1,367
    Definitely sounds like a pump or air problem, did you bleed the pump when re-filling? Any thumb vents anywhere?
    Feb 2009
    49
    Default
    Thanks guys. Didn't see any finger vents, but did a women's look....lol.
    Mains flush it is then.....
    EPH
    EPH is offline
    Plumbers Arms member EPH's Avatar
    Jun 2011
    585
    Default
    Fitted loads of these along with Glowworm Ultimates, really good boilers
    West Sussex
    600
    [QUOTE=EPH;183681]Fitted loads of these along with Glowworm Ultimates, really good boilers.
    I think those boilers started my bad back, god they were heavy.
    EPH
    EPH is offline
    Jun 2011
    585
    Default
    [QUOTE=Kev the gas;183908]
    Quote Originally Posted by EPH View Post
    Me too, where's there's blame there's a claim!!
    Top Plumbing Forum Contributor arran197's Avatar
    Aug 2011
    Wolverhampton
    701
    Definitely sounds like an air lock. If there is a drain off above the boiler, attach a hose to it and fill the system whilst having the drain off open. It pulls the water and air out the system.
  1. Ideal Classic Slimline FF350
    By willing2learn in forum Gas Safe Register Forum - Public Forum
    Last Post: 21-01-2011, 09:18 AM
  2. Ideal Classic - Vibrating Fan
    By plm in forum Central Heating Forum
    Last Post: 20-12-2010, 12:52 AM
  3. Ideal Classic NF80 problem
    By jnw in forum Central Heating Forum
    Last Post: 27-05-2010, 09:20 PM
  4. ideal classic nf 50
    By radford in forum Plumbing Forum
    Last Post: 08-02-2010, 09:01 PM
  5. Ideal Classic Boiler problem
    By GEOFF BRADBURY in forum Plumbing Forum
    Last Post: 10-01-2010, 10:52 PM
ideal classic ff350 manual
ideal classic ff350 not lighting
classic ff350
ideal classic boiler ff350
ideal classic ff350
ideal classic ff350 problemclassic ff350 manual
