Results 1 to 15 of 15
Plumbing & Plumbers Forum - Pulling my hair out trying to use the white key on my Greenstar 24i
Discuss Pulling my hair out trying to use the white key on my Greenstar 24i in the Central Heating Forum at Plumbers Forums; My water pressure is at zero so I know that I need to increase the water pressure. I seem to remember that because I have a new model, the 24i ...-
31-07-2011 #1New to Plumbing Forum
- Jul 2011
My water pressure is at zero so I know that I need to increase the water pressure. I seem to remember that because I have a new model, the 24i Junior, that the white key, currently stored under the boiler locked into a hole, needs pulling out and inserting into the square white hole next to it.
Well the white key won't come out. I've tried turning it, pulling it, pushing it and pulling it etc etc and it's locked in place. Well actually it finally did come out but it pulled out something that looked like it wasn't supposed to come out and a trickle of water came out. I've place the key back where it's supposed to be and the hot water seems to be working.
Who designs such non-customer friendly ways of doing things? i've shredded my hand open in the process doing something that is supposed to be easy right?
Some advice please
Thank you
31-07-2011 #2Plumbers Arms member
- Sep 2009
- South Yorkshire
- 2,436
- 48
- Thanked 205 Times in 199 Posts
Re: Pulling my hair out trying to use the white key on my Greenstar 24i
If you have got it out and your preesure is ok then all is fine. There is always a little bit of water released when the filling key is removed.
Its the new plastic department that start at worcester about ten years ago that designed it, there next boiler will be all plastic and only weigh 1 lb but cost several thousand more
31-07-2011 #3New to Plumbing Forum
- Jul 2011
Nope the pressure is the same as what I pulled out wouldn't fit in the square hole.
31-07-2011 #4Plumbers Arms member
- Apr 2010
- 1,399
- 61
- Thanked 167 Times in 157 Posts
Sounds like the bypass key is already in place.
All you need to do now is turn the little square knob(white) at the side of the key till the water starts to flow and pressure rises to 1.5bar(ish).
31-07-2011 #5Plumbers Arms member
- Dec 2010
- 1,365
- 103
- Thanked 99 Times in 98 Posts
Sounds like it was in the right place to start with. The square white nob needs to be turned anti clockwise, by hand, with the white key locked in place to top up the pressure. Its not a bad design, its your understanding of it causing the issues.
31-07-2011 #6
31-07-2011 #7UK Plumbersforums Trusted Advisor.
- Mar 2010
- lincolnshire
- 3,737
- 297
- Thanked 374 Times in 357 Posts
and being a worcester it will leak.
31-07-2011 #8
31-07-2011 #9Plumbers Arms member
- Jul 2011
- Wales
- 799
- 11
- Thanked 59 Times in 57 Posts
It's simple when you know how. The key makes the gap between the cold inlet and the heating return. That's why it has to o-rings on it.
They do become stuck if they get left in the valve, I think the o-rings must swell.
31-07-2011 #10uɐɯ sɐƃ moderator
- Jan 2010
- maesteg,south wales
- 13,343
- 827
- Thanked 1,266 Times in 1,209 Posts
worcesters are poo but everyone knows i hate them anyway so stating the obvious
GASMAN
01-08-2011 #11Top Plumbing Forum Contributor
- Nov 2009
- 421
- Thanked 21 Times in 21 Posts
I think you are saying it's already in the hole. If it is (already plugged in, then it's in the right place, leave it. Normally it is clipped flat in the plastic tray below. If you check it out (u may need a torch!!) you'll see the ket has has an arrow shape on it, on the black housing there is a lock either open or closed. Turn to your required place
02-08-2011 #12Top Plumbing Forum Contributor
- Aug 2011
- Wolverhampton
- 701
- Thanked 49 Times in 47 Posts
I would agree in saying they are poo. They do release water when you pull them out, as others have said.
03-08-2011 #13Super Plumbing Forum Contributor
- May 2009
- nb b
- 1,603
- Thanked 42 Times in 41 Posts
04-08-2011 #14
I dont know is the simple answer, I posted the link to show how to fill the boiler.
04-08-2011 #15UK Plumbersforums Trusted Advisor.
- east london
- 6,666
- 9
it s droping into a condensate pump but shouldnt be inside the white pipework
newbie pulling my hair out help please shower pump !!
By petespeed in forum Bathrooms, Showers and WetroomsReplies: 21Last Post: 06-04-2011, 11:05 PM -
Problems with secondary return pump. Pulling my hair out!!!
By Plucky in forum Central Heating ForumReplies: 21Last Post: 04-04-2011, 10:49 PM -
Pump Pulling air
By Whitcop in forum Central Heating ForumReplies: 4Last Post: 11-12-2010, 09:30 PM -
Boiler not pulling oil up
By flexouk in forum Central Heating ForumReplies: 1Last Post: 17-05-2010, 09:26 PM -
10k wages...is someone pulling my leg?
By Smcart5 in forum Plumbing ForumReplies: 26Last Post: 31-03-2010, 11:14 AM
1Likes
gas explosion in notts
