Results 1 to 14 of 14
Plumbing & Plumbers Forum - whats the most cost efficient system
Discuss whats the most cost efficient system in the Central Heating Forum at Plumbers Forums; is a combination boiler the most efficient system.not instalation cost, running cost with natural gas....-
27-07-2011 #1Super Plumbing Forum Contributor
- May 2009
- nb b
- 1,603
- Thanked 42 Times in 41 Posts
27-07-2011 #2fuzzyGuest
Re: whats the most cost efficient system
i guess so because you only heat what you need
beware though that the power required is a lot as its instant, hence the larger boilers
27-07-2011 #3Super Plumbing Forum Contributor
- May 2009
- nb b
- 1,603
;punter has a system boiler at present,3 bed,1 bathroom,1 ensuite ,3 adults, 2 toilets,wants running costs reduced, and seems set on a combi and to be fair he's probs right, any thoughts.
27-07-2011 #4Plumbers Arms member
- Jun 2011
- Wymington
- 140
- 13
- Thanked 14 Times in 13 Posts
27-07-2011 #5Super Plumbing Forum Contributor
- May 2009
- nb b
- 1,603
27-07-2011 #6Plumbers Arms member
- Feb 2009
- chesterfield
- 849
- 53
- Thanked 29 Times in 29 Posts
unvented?? or is this out of custards money spec??
27-07-2011 #7Plumbers Arms member
- Sep 2009
- South Yorkshire
- 2,436
- 48
- Thanked 205 Times in 199 Posts
Combi`s are good for one thing one person one bathroom single use / also good for the instaler because there easy.
If the existing instalation has a HWC then it`s futile to remove and fit a less sufficient system
27-07-2011 #8Super Plumbing Forum Contributor
- May 2009
- nb b
- 1,603
totally agree,but punter thinks in the long run he'll save money, because as we know combi's use gas when asked too, i suppose you've got an element of control, they. the punter think heating a cylinder full of water is a waste when you can have hot water on tap as with combi,what can i say to make him change his mind.
28-07-2011 #9UK Plumbersforums Trusted Advisor.
- Mar 2010
- lincolnshire
- 3,737
- 297
- Thanked 374 Times in 357 Posts
Combi's are very inefficient in reality
28-07-2011 #10fuzzyGuest
so he is looking for cheapest to run, not necessarily the best type or suitable system
28-07-2011 #11UK Plumbersforums Trusted Advisor.
- Oct 2010
- Glasgow, Scotland
- 4,696
- 324
- Thanked 260 Times in 254 Posts
tell him with combi if it brakes down he has no back up, but with cylinder he has an immersion heater, and he would need a big combi for any decent flow rates which would use alot of KWs when heating the hot water, where as a system boiler wont use as much KW to heat the cylinder. Customers just like the idea of instant hot water on demand without having to heat it up first
30-07-2011 #12Super Plumbing Forum Contributor
- May 2009
- nb b
- 1,603
30-07-2011 #13Plumbers Arms member
- May 2009
- south croydon
- 93
Water usage may go up with the combi depending on the pipe runs since the hot water may have more pipework to heat before it reaches the taps. Biggest potential hassle will be total reliance on the boiler (ie no immersion) unless he also installs an electric shower in the ensuit. Also likely to get leaks from poor joints on previous gravity head supplied pipes that are now subject to mains pressure.
If you are going to do it do it right the first time.
www.plumbandelec.co.uk
31-07-2011 #14Plumbers Arms member
- Jan 2011
- MOLD, N Wales
- 276
- 7
- Thanked 17 Times in 16 Posts
Whats the best plumbing van alarm system?
By mutley racers in forum Plumbing ForumReplies: 41Last Post: 18-10-2012, 08:12 PM -
Cost of system upgrade (unvented)??
By Copper Top in forum Plumbing ForumReplies: 23Last Post: 27-04-2011, 07:21 PM -
Are radiators energy efficient?
By Lorna3 in forum Central Heating ForumReplies: 49Last Post: 19-04-2011, 06:35 PM -
cost of system boilers !!
By Puddle in forum Central Heating ForumReplies: 5Last Post: 08-08-2010, 06:46 PM -
Estimate cost for a new Central heating system
By hit0062 in forum Central Heating ForumReplies: 5Last Post: 25-03-2010, 02:08 PM
stanley tool bag
3 Minutes Ago in Plumbing Tools
