Results 1 to 11 of 11
Plumbing & Plumbers Forum - Filling loop and topping up probs on Vaillant ecotec plus 837
Discuss Filling loop and topping up probs on Vaillant ecotec plus 837 in the Central Heating Forum at Plumbers Forums; Cannot get mains water to flow into system using filling loop. Filling loop connected, both stop valves open and only about 0.9bar in the system but mains water (plenty of ...
    Jul 2011
    Default Filling loop and topping up probs on Vaillant ecotec plus 837
    Cannot get mains water to flow into system using filling loop. Filling loop connected, both stop valves open and only about 0.9bar in the system but mains water (plenty of mains pressure) will not flow into the system. I have uncoupled the filling loop at the stop valve (at the other end to the double check valve) and proved mains water pressure is flowing through the filling loop.
    Any ideas on my next move would be greatly appreciated. I should add that the system is working OK, just want to top up the system pressure. Also I have used this filling loop to top up the system pressure on previous occasions without problem. And no I don't have a system leak, natural degradation of system/line pressure.
    mikegas's Avatar
    Feb 2010
    1,213
    Default
    Try it without the check valve, and replace if jammed
  3. Last edited by mikegas; 24-07-2011 at 08:55 AM.
  4. The Following User Says Thank You to mikegas For This Useful Post:
    dicksibo (24-07-2011)
  5. #3
    Kev the gas's Avatar
    West Sussex
    610
    Default Re: Filling loop and topping up probs on Vaillant ecotec plus 837
    is your mains pressure only .9 of a bar?
    "and only about 0.9bar in the system but mains water (plenty of mains pressure)" Have you tested this with a gauge?
    Is the pressure gauge on the boiler faulty?
  6. The Following User Says Thank You to Kev the gas For This Useful Post:
  7. #4
    Plumbing Forum Contributor
    Jul 2008
    81
    press the minus button on the front of the boiler, this will give you the "electronic" pressure of the system, it will tell you if the guage is faulty ,more likely to be a stuck nrv.
  8. The Following User Says Thank You to bill577 For This Useful Post:
  9. #5
    Jul 2011
    If only it where that simple, the nrv is push fit and retained by a cir-clip, not a threaded connection. I've had the nrv out and checked for directional flow, it appears to be working OK. Unless any better ideas come up my next move is to remove and check the service valve that the filling loop connects to. The service valve has a bleed point fitted and when cracked open this works OK.
    Looks like I've got to drain the system down, was trying to avoid that palaver.
  10. #6
    Jul 2011
    Quote Originally Posted by Kev the gas View Post
    0.9bar in system; mains pressure at least 2.0bar. Boiler pressure gauge appears to be OK, generally agrees with what LCD displays says when I press "i"
  11. #7
    Jul 2008
    81
    there are two taps to the filling loop, because the handles are made of plastic they some times appear to be turning but are not opening the valve, take the handles off (just a small screw in the middle )and use a spanner to open the valves.
  12. The Following User Says Thank You to bill577 For This Useful Post:
  13. #8
    Jul 2008
    81
    you can see the valves here.
    Attached Images Attached Images
  14. The Following User Says Thank You to bill577 For This Useful Post:
  15. #9
    Jul 2011
    Quote Originally Posted by bill577 View Post
    Tried that bill577, both valves are turning thru 90degrees OK. Worth a try though
  16. #10
    SafeGasInstall's Avatar
    Oct 2010
    Northampton
    6,209
    faulty pressure gauge or sludge in system ! drain down to 0.0 bar ,then start filling up if then you hear water going in this will mean that if there is 2.0 bar mains pressure you have faulty/sludge pressure gauge !
    make sure you open both flow and return valves under boiler
  17. The Following User Says Thank You to SafeGasInstall For This Useful Post:
  18. #11
    Oct 2010
    Northampton
    6,209
    when open they must been in line with pipe work ,you will need alen key or big screw diver ,make sure you do not damage them
  1. filling loop for megaflo boiler?
    By bluesky in forum Central Heating Forum
    Last Post: 01-07-2011, 09:58 PM
  2. Intergrated filling loop
    By bob the plumber in forum Gas Safe Register Forum - Public Forum
    Last Post: 22-06-2011, 09:01 PM
  3. Can't Find My Filling Loop!
    By Straker in forum Central Heating Forum
    Last Post: 02-03-2011, 10:42 PM
  4. Can't find Filling loop
    By zoee in forum Central Heating Forum
    Last Post: 04-01-2010, 07:33 PM
  5. no filling loop
    By Tonto123 in forum Central Heating Forum
    Last Post: 03-01-2010, 08:38 PM
vaillant ecotec plus filling loop
vaillant ecotec filling loop blocked
vaillant boilers filling loop
vaillant ecotec plus filling taps
vaillant ecotec plus cant fill up
vaillant ecotec plus top up pressure
vaillant ecotec plus 837 top up pressure
