Results 1 to 6 of 6
Plumbing & Plumbers Forum - stainless steel flexi pipe instead of pex and copper
Discuss stainless steel flexi pipe instead of pex and copper in the Central Heating Forum at Plumbers Forums; Has anyone used the flexible stainless steel pipe ( similar to gas track pipe) for new heating systems or general plumbing. I had a look at it today in suppliers ...-
11-07-2011 #1Plumbing Forum Contributor
- Feb 2011
- 46
- Thanked 4 Times in 4 Posts
Has anyone used the flexible stainless steel pipe ( similar to gas track pipe) for new heating systems or general plumbing. I had a look at it today in suppliers and it looks good. Slightly more expensive than pex but cheaper than copper. Has all the strength of copper but flexibility of pex. I'm going to try it on the next heating system i do in a week.
11-07-2011 #2Plumbers Arms member
- Oct 2009
- Nottingham
- 1,672
- 57
- Thanked 132 Times in 121 Posts
Re: stainless steel flexi pipe instead of pex and copper
Is the internal bore smooth?
11-07-2011 #3UK Plumbersforums Trusted Advisor.
- Apr 2011
- Newcastle Upon tyne
- 6,046
- 299
- Thanked 769 Times in 743 Posts
What the 'f' is "pex"? I've heard of and seen 'trak' pipe........... Is this for gas or water?
11-07-2011 #4
Don't fix the floorboards down too tight!
11-07-2011 #5Top Plumbing Forum Contributor
- Oct 2008
- 685
- 6
- Thanked 38 Times in 36 Posts
Probably the same stuff you get for solar. Does it come pre insulated?
13-07-2011 #6Plumbing Forum Contributor
- Feb 2011
- 46
It's the same construction as solar pipe but the wall thickness is a few mm thinner. It's not a smooth bore which would worry me about sediment build up. I'm going to suggest it on my next heating system but have to talk to manufacturers technical department first. I don't think it comes pre insulated but i only had a quick look the last day in the suppliers. I'll try and post some pictures and any documentation i get.
Stainless steel cylinders, are they any good????
By bruceyboy in forum Plumbing ForumReplies: 13Last Post: 22-06-2011, 08:03 PM -
gledhill stainless steel cylinder.
By pauls in forum Plumbing ForumReplies: 10Last Post: 26-02-2011, 10:12 PM -
compression rings on stainless steel.
By thebeatmeister in forum Fittings & PipesReplies: 8Last Post: 16-07-2010, 11:27 PM -
Stainless steel pipe in domestic plumbing
By dave1234 in forum Plumbing ForumReplies: 6Last Post: 26-06-2010, 07:54 PM -
galvanized steel pipe to copper fitting?
By that bloke. in forum Fittings & PipesReplies: 5Last Post: 23-04-2010, 11:21 PM
Setting Honeywell DU145 Auto...
5 Minutes Ago in Central Heating Forum
