Results 1 to 11 of 11
Plumbing & Plumbers Forum - Help! Got a back boiler but need new fire front
Discuss Help! Got a back boiler but need new fire front in the Central Heating Forum at Plumbers Forums; Hi Guys Hope someone can help, as I'm completely flumoxed on what to do next... We have a back boiler in our front room, which has just been serviced shortly ...-
05-06-2011 #1New to Plumbing Forum
- Jun 2011
Hi Guys
We have a back boiler in our front room, which has just been serviced shortly after we moved in. It seems very efficient to us and works really well, so we're reluctant to rip it out to put a new fangled 'combi-boiler' in. Obviously to do that would cost a lot of money and we can't really see the point.
So we were told to put a new fire front onto the boiler, but I can't seem to find anything out about this. Would we have to buy a new back boiler to go with the fire front anyway? Or could we just get the front to put onto the existing boiler, as that's all we need?
If anyone has any thoughts, they'd be much appreciated!
Thanks.
05-06-2011 #2Plumbers Arms member
- Apr 2011
- Skewen / Swansea
- 216
- Thanked 24 Times in 24 Posts
Re: Help! Got a back boiler but need new fire front
What boiler is it would help us?
05-06-2011 #3uɐɯ sɐƃ moderator
- Jan 2010
- maesteg,south wales
- 13,355
- 828
if its a baxi 552 or 401 bermuda or later you can get a gsr engineer to fit a second hand fire,obviously it has to be a baxi fire suitable for your boiler and you would need the relevant parts to go with it these normally include a fire fixing pipe,wall fixing bracket,controls heat shield,mi,s and a fire support tray if required
http://shop.ebay.co.uk/i.html?_kw=ba...wusc=baxi+burm if a baxi lots of choiceLast edited by gas man; 05-06-2011 at 01:52 PM.
GASMAN
05-06-2011 #4Plumbers Arms member
- Jun 2010
- 698
- 11
- Thanked 107 Times in 106 Posts
If your fire boiler unit is any other make other than Baxi, you need to change the whole unit.
Baxi used to do fire front replacements for certain back boiler Bermuda range, but if boiler old & you put a new fire onto it [ if allowed & available, it'll cost alot more than a standard fire] Your boiler will need replacing in a few years, you'll be paying again & fire might not fit!
Baxi do an HE back boiler with a selection of fires.
The other point is your system may not be fully controlled, ie cylinder stat & room stat [ boiler interlock] & therefore inefficient.
05-06-2011 #5Top Plumbing Forum Contributor
- Jun 2011
- Kent
- 417
- 32
- Thanked 50 Times in 33 Posts
baxi do the only HE back boiler on the market now here is the link Baxi Bermuda Back Boiler
compatible with Baxi UK Valor fires.
05-06-2011 #6New to Plumbing Forum
- Jun 2011
Hi
Thanks for all your comments so far. I have no idea what make the boiler is, but the central heating programming panel says Honeywell, so I guess that's it?
Now I'm really confused, haven't a clue what to do.
What is everyone's feelings on this?
As I said, the boiler has just been serviced, has nothing wrong with it and seems fairly efficient. The only reason I need to do anything at all is because we currently have a hideous 1970's ceramic bar fire on the chimney breast and need to get rid of it and get something more modern or ageless.
Any thoughts???
05-06-2011 #7uɐɯ sɐƃ moderator
- Jan 2010
- 13,355
- 828
post up a picture
GASMAN
05-06-2011 #8UK Plumbersforums Trusted Advisor.
- Dec 2009
- Coatbridge, Lanarkshire
- 3,515
- 52
- Thanked 342 Times in 315 Posts
the heating programmer can be any make, look at the boiler and/or fire and identify and name or number you can see, someone will be able to identify it from whatever info you can see, some fires have a badge/label next to the control knob, or look at the bottom of the fire, there will be a removable panel to get into the boiler pilot, there will be some info about there which will identify it, you might get a new fire for certain boilers but will prob need to pay about £500 for one, and TBH the new ones arent great to look at,
05-06-2011 #9UK Plumbersforums Trusted Advisor.
- east london
- 6,666
- 9
05-06-2011 #10Plumbers Arms member
- Mar 2011
- Leeds
- 432
- 45
- Thanked 20 Times in 20 Posts
The best advice would be to remove it all and get a combi, much cheaper to run in the long run and a combi is much safer.
06-06-2011 #11New to Plumbing Forum
- Oct 2010
- 29
- 8
- Thanked 2 Times in 2 Posts
I have got radiant fire you can have for free. Fire is almost new you will have to het someone to install it tough.
Back boiler Fire Front.
By egg661 in forum Central Heating ForumReplies: 6Last Post: 24-05-2011, 11:08 AM -
Coal fire Back boiler
By Graeme Geddes in forum New Member IntroductionsReplies: 3Last Post: 07-05-2011, 09:57 AM -
Baxi rg3 fire front
By P J F PLUMBING in forum For-sale & wanted .Replies: 7Last Post: 27-02-2011, 01:11 AM -
Open fire back boiler
By pianorealm in forum Plumbing ForumReplies: 8Last Post: 31-01-2011, 07:29 AM -
Back boiler/fire
By natwill in forum Gas Safe Register Forum - Public ForumReplies: 23Last Post: 05-12-2010, 08:13 PM
spot the boiler
10 Minutes Ago in Plumbing Forum
