Results 1 to 12 of 20
Plumbing & Plumbers Forum - Saunier Duval Semia Condens F24
Discuss Saunier Duval Semia Condens F24 in the Central Heating Forum at Plumbers Forums; Can anyone help. I've been out to a Semia Condens F24 and its not rectifying. after 6-8 secs it goes to lock out. I noticed the probe was damaged so ...
    Mar 2011
    Default Saunier Duval Semia Condens F24
    Can anyone help.
    I noticed the probe was damaged so I replace..I disconnected the condense earth lead. checked gas pressures..
    all ok. I spoke with Saunier who said it was prob ignition pcb. I fitted one and still the same..
    With the ignition box off and my multi meter in the top and bottom connections where they plug onto the gas valve I get 180v for a second the drops out.
    any ideas..
    uɐɯ sɐƃ moderator
    gas man's Avatar
    maesteg,south wales
    13,567
    Default Re: Saunier Duval Semia Condens F24
    test the probe AND lead for continuity before replacing pcb,s
  3. GASMAN
    IMPOR
    Mar 2011
    thats the first thing i did as the probes (come with leads attached) were damaged so replaced..
    didn't work so I changed ignition pcb..
    still not rectifying..
    uɐɯ sɐƃ moderator
    gas man's Avatar
    maesteg,south wales
    13,567
    http://www.saunier-duval.co.uk/manua...structions.pdf
    looking at this,it has a trap sensor simple screw type connection? is it sound would have thought theres only continuity here if the conden backs up,you have proven continuity on the detection electrode and lead,is the gap right? is it cross lighting?is it arcing trough a bad gromit on the combustion box?you have replaced pcb,is it just the one fitted finally and importantly all these checks dont mean a thing if you have reversed polarity if you have not checked for this it will give these symptoms and blow your new pcb
    GASMAN
    IMPOR
    May 2011
    county durham
    443
    made sure the airswitch is ok ? ive done one where it let the boiler kick in for a second than off.. annoying
    Mar 2011
    tested everything in manual. Inc polarity and linked out condensate sensor
    manufacturer said gas valve but checked.
    will try linking out aps.
    May 2011
    county durham
    443
    i know that feeling you get after spending 100 quid on a pcb and it still not working..
    always best to buy the little things first, thermistors etc..
    SafeGasInstall's Avatar
    Oct 2010
    Northampton
    6,225
    did u check gas valve solenoids
    May 2011
    county durham
    443
    how is that possible ? i'd love to know
    Oct 2010
    Northampton
    6,225
    May 2011
    county durham
    443
    If the ignitor glows for several seconds (up to 15 seconds) and then goes out, the problem is probably the coils (solenoids). If the ignitor glows and stays on, then the problem is usually the flame sensor. If it ignites and then quickly goes out, it is most likely a problem with inadequate air flow
    does this apply ?
  13. #12
    May 2011
    county durham
    443
    Quote Originally Posted by SafeGasInstall View Post
    top man, never seen one before, cheers
  1. Saunier Duval semia condens F24e not regulating temperature
    By Mears in forum Gas Safe Register Forum - Public Forum
    Last Post: 24-04-2013, 10:46 PM
  2. Semia condens f24 boiler pressure
    By Jonnyreyn in forum Central Heating Forum
    Last Post: 12-05-2011, 09:41 PM
  3. Saunier duval sd 30e
    By bambibashercol in forum Central Heating Forum
    Last Post: 22-02-2011, 05:56 PM
  4. sauiner duval semia condens f 24 e ..cutting out. FML!!
    By craigallan90 in forum Central Heating Forum
    Last Post: 18-02-2011, 10:55 AM
  5. saunier duval
    By paulfrench in forum Central Heating Forum
    Last Post: 02-06-2010, 10:36 AM
sema conde f24e instruction manual
saunier duval sema conde f24e manual
saunier duval semia f24
saunier duval semia
saunier duval semia condens f24 flue temp.sensor
saunier duval f24 manual
saunier duval semia condens f 24 installation instructions
