Results 1 to 15 of 23
Plumbing & Plumbers Forum - Potterton combi 80 central heating running then cutting out then back on again
Discuss Potterton combi 80 central heating running then cutting out then back on again in the Central Heating Forum at Plumbers Forums; Hi please could you help i have a combi 80 the central heating runs for 5mins or so then stops & then starts up again then repeats....
    Default Potterton combi 80 central heating running then cutting out then back on again
    moony's Avatar
    Oct 2009
    1,205
    Default Re: Potterton combi 80 central heating running then cutting out then back on again
    circulation or room stat.
  3. www.q-plumb.co.uk for all your plumbing needs
    Hi moony Ive got no room stat fitted the boiler has had a new pcb board
    moogwai's Avatar
    Dec 2009
    birmingham
    1,134
    Default
    Have these boilers got the filters inside flow and return valves??? Turn valves off drain down boiler and remove filters and clean. Deffo sounds like a circulation problem.
    Sent from my Desire HD using Tapatalk
    Hi moogwai i cant see eny filters in there.
    Oct 2010
    111
    Are the radiators getting hot ? does the central heating temperature dial on the front of the boiler rotate fully from the minimum setting to the maximum ? [ if it was a clock from 12 - 9 ?]
    moogwai's Avatar
    Dec 2009
    birmingham
    1,134
    Quote Originally Posted by richardo View Post
    can you post a pic of the valves to see if im right about them? if im right you can unscrew the front cap on the valve and remove a filter....it'll be like a cylindrical gauze...get yer finger in there and have a feel!!
    moogwai's Avatar
    Dec 2009
    birmingham
    1,134
    no your right.....it dont have the valves on that i thought...just looked at the manual for it.
    Hi rads are getting hot & the mechanical timer is working.
    Oct 2010
    111
    I dont mean the timer !! You should have a central heating temprature dial on the front of the boiler it should move from the 12oclock[ min temp] position round to the 9oclock position [ max temp]
    No there is no clock but there is an adjuster on the pcb board
  13. #12
    moogwai's Avatar
    Dec 2009
    birmingham
    1,134
    could be the ch sensor
  14. #13
    Oct 2010
    111
    NOOOO im not talking about any clock !!! just on about the central heating dial,on the front of the boiler and where it should move to and from !!
  15. #14
    moogwai's Avatar
    Dec 2009
    birmingham
    1,134
    Quote Originally Posted by mattyp View Post
    lol.....mattyp calm down before you have a seizure.....by looking at the manual it doesnt look like the 80combi have a ch temp dial.
    and to be honest i think the boiler is coming to the end of its life and some parts may be obsolete......so if you can i'd look at renewing.
  16. #15
    Oct 2010
    111
    Im ok mate ! just trying to help, as you know it can be very hard !!
  1. Wood burner with back boiler and Oil fired central heating
    By Daviddonk in forum Plumbing Forum
    Last Post: 01-02-2011, 07:58 PM
  2. Running central heating with no radiators
    By ziggy in forum Central Heating Forum
    Last Post: 15-01-2011, 05:30 PM
  3. Potterton Combi 80 Central Heating Problem
    By ttj in forum Central Heating Forum
    Last Post: 19-11-2010, 03:41 PM
  4. Combi cutting out when running shower
    By joe brown in forum Plumbing Forum
    Last Post: 09-02-2010, 09:52 PM
  5. Central Heating expansion constantly running
    By Dunston in forum Central Heating Forum
    Last Post: 24-11-2008, 08:39 AM
potterton combi 80 tempreature sensor
central heating runs for 5 minutes and then stops
combi poterton combi 80 boiler cuts out after about 1 minute
potterton combi 80 temperature
potterton combi 80 central heating
potterton 80 combi boiler keeps cutting out
potterton combi 80 heating keeps cutting out
