Results 1 to 12 of 15
Plumbing & Plumbers Forum - Potterton system - low pressure
Discuss Potterton system - low pressure at UK Plumbers Forums; Hi There I have a potterton system boiler. I bled a rad and now have no pressure, can anyone tell me where I attach the filling loop hose The two ...
    Jan 2011
    Default Potterton system - low pressure
    Hi There
    The two pipes under the boiler with the plastic valves on them have been capped are different sizes - is this unusual ?
    There is a third capped pipe connected also but this doesnot have a plastic valve - which two do i connect to ?
    Jan 2011
    Default Re: Potterton system - low pressure
    Jun 2010
    703
    Your filling loop will be else where, cupboard underneath boiler, cylinder cuboard, under sink or is some of the piping boarded in ?
    The 2 valves at each side are heating flow & return. The filling loop requires a cold water pipe to link to a heating pipe.
    Jan 2011
    Thanks - I'll go have a better look
    I also found the video below - is it relevant to my system ?
    May 2008
    700
    [QUOTE=aggis;111989]Your filling loop will be else where, cupboard underneath boiler, cylinder cuboard, under sink or is some of the piping boarded in ?
    The 2 valves at each side are heating flow & return. The filling loop requires a cold water pipe to link to a heating pipe.[/QUOTEy
    i made that mistake once asked the customer where filling loop was and got a blank look. i explaned what it looked like and still blank look so i got one and fitted it to boiler. a day later i got a phone call saying can i remove that silver pipe thingy we have one of them under the sink
    Jan 2011
    It's definitely well hidden !!! - but anyway I managed to find a pro - he is calling over tomorrow ! I will post where it is when he finds it -
    May 2009
    7,289
    if not near boiler,usually in hot water cylinder cupboard
  8. The Following User Says Thank You to Puddle For This Useful Post:
    Jan 2011
    Ok - the plumber was here -
    He said there is no filling loop- that the boiler is gravity fed - he will fit one tomorrow - nothing that he can do tonight, so another night of freezing my knackers off.
    Seems to me there must be a way of getting water in - or how was it filled when installed ?
    Any ideas anyone ?
    Jan 2011
    I did it ...I fixed it .... I'm warm now...
    Thanks to everyone ... what got it in the end was ... a syringe, a piece of hose pipe and a spanner !!
    Thank you and good night.
    uɐɯ sɐƃ moderator
    gas man's Avatar
    18,661
    what potterton is this? none are gravity
    Jan 2011
    It just says Potterton system on it
  13. #12
    oldplumber
    take a look in your attic, for some reason some people/installers connect up the filling loop on the old cistern fed part of the system and they get calledback to fill it when the pressure drops as the owners cant find a filling point! found 2 like that last year.
  1. Potterton Performa 18e-No Pressure,noisy and no HW or CH
    By jamiem in forum Gas Safe Register Forum - Public Forum
    Last Post: 22-02-2013, 06:06 PM
  2. Potterton he plus low pressure
    By baggiesdaddy in forum Plumbing Forum
    Last Post: 19-10-2012, 11:04 AM
  3. Potterton loosing pressure
    By marsaday in forum Central Heating Forum
    Last Post: 11-06-2012, 09:10 AM
  4. Potterton Powermax HE pressure
    By Simon P in forum Plumbing Forum
    Last Post: 20-08-2011, 01:11 PM
  5. Potterton Promax System HE plus
    By gt568 in forum Gas Safe Register Forum - Public Forum
    Last Post: 20-05-2010, 09:11 PM
  6. Potterton Promax System HE plus
    By gt568 in forum Central Heating Forum
  7. potterton boiler pressure way too high - HELP!
    By Steve100 in forum Central Heating Forum
    Last Post: 10-04-2010, 10:34 PM
potterton gold combi he low pressure
how to repressurise a potterton boiler
repressurise potterton boiler
repressurising potterton boiler
potterton boiler pressure too low
