Chatrooms
baxi 105E combi pressure rise. -
Notices
Old 17-12-2008   #1 (permalink)
gazza247
Info
Default baxi 105E combi pressure rise.
Hello there, I've got a baxi 105E combi thats gaining pressure very slowly, If I set pressure to 2bar It rises to 2.5 bar in about tens minutes. The heating works fine and the does hotwater hot water operates no problem. But can't figure out why the rise in pressure , Any suggestions are welcome. Recently changed both diverter seals as they were leaking this was about 3 months ago.
The relief valve opens and does its job, any suggestions please?
gazza247 is offline
Old 24-12-2008   #2 (permalink)
Phoenix Heating
Info
Default Re: baxi 105E combi pressure rise.
only way pressure can increase is either........filling loop not closed or disconected, secondary hot water heat exchanger leaking (mains water getting into ch ) if ur boiler has one, not familiar with this model
__________________
www.phoenixheatingltd.co.uk
Phoenix Heating is offline
combi boiler losing pressure ice cold Central Heating Forum 19 06-01-2010 12:26 PM
Baxi 80 Combi - How to increase DHW pressure? noelpilot Plumbing Forum 2 17-12-2008 08:11 AM
Leaking Baxi Combi robbo32 Plumbing Forum 4 10-12-2008 07:37 AM
Baxi 80 combi boiler rmbp Central Heating Forum 3 29-11-2008 08:28 PM
Pressure problem in condensing combi robbo32 Plumbing Forum 4 13-11-2008 12:00 AM
