Results 1 to 11 of 11
Plumbing & Plumbers Forum - Needs no explanation.
Discuss Needs no explanation. in the Central Heating Forum at Plumbers Forums; flue.jpg Can you spot the installation fault?...
    Jan 2008
    North Yorkshire
    4,150
    Default Needs no explanation.
    Banned
    Jul 2009
    North Devon
    1,889
    Default Re: Needs no explanation.
    180 about by any chance, cant see clearly no specs on
    Jan 2008
    North Yorkshire
    4,150
    I should have added it's an oil boiler. There are actually about 8 other installation faults you can't see in the photo.
    tamz's Avatar
    Scotland
    9,384
    As old plumb said it is hard to see from the angle.
    No sleeve on oil pipe.............i can see that but i gather it is something with the flue?
    Geez a clue
    Jan 2008
    North Yorkshire
    4,150
    Sleeve is only needed on underground oil pipe.
    Clue - It's not on the flue itself (though the flue is only about 3ft away from the garage wall opposite). Click on image to zoom.
    tamz's Avatar
    Scotland
    9,384
    Is that a gap in the stonework above the flue?
    Hard to see.
    I always sleeve any pipe passing through brickwork as good practice.
    Jan 2008
    North Yorkshire
    4,150
    The pipe is sleeved where it passes through the brickwork.
    Nothing to do with the flue.
    Banned
    Jul 2009
    North Devon
    1,889
    dont know about oil but is that a fire cut off on the outside away fm boiler and flue output looks a bit sooty
    tamz's Avatar
    Scotland
    9,384
    The hand wheel fire valve. Fine if the kids set fire to the wheelie bin sitting next to it
    Had to think about that one and looking in the wrong place.
    Jan 2008
    North Yorkshire
    4,150
    Yes, that is the only fire valve on the system!
    Other faults
    Suction pipe 10mm diameter (should be 8mm)
    Flue 1m away from opposite wall (wind affects FGA readings)
    Wall hung model - installer has not left sufficient space to access it properly for servicing (without requiring a joiner).
    Burner connected to boiler with rigid pipe (no flexi oil lines)
    Baffle cover leaks like a sieve (fumes inside house)
    Filter on tank sitting on concrete - not enough room underneath for a spanner or to remove it for cleaning.
    Tank not fully supported on base, less than 1.8m from openings. Under non-fire rated eaves.
    tamz's Avatar
    Scotland
    9,384
    Looks like he may have hung the boiler a bit low at the first attempt going by the joints on brickwork.
    All in a days work
  1. Combi Boiler Explanation
    By Monkfish in forum Central Heating Forum
    Last Post: 16-01-2010, 03:56 PM
fire rated eaves details
