Results 1 to 4 of 4
Plumbing & Plumbers Forum - Britony combi se
Britony combi se
Discuss Britony combi se in the Central Heating Forum at Plumbers Forums; Hello wondering if anyone can point me in the right direction. I went to look at this combi earlier and it is giving me flame detection fault. the ignition process ...
    Default Britony combi se
    Hello wondering if anyone can point me in the right direction. I went to look at this combi earlier and it is giving me flame detection fault. the ignition process starts fan and pump run, but then stops before even attempting to ignite. The air pressure switch seems to be working ok the ,continuity is switching between connections. The fault find is rubbish in the manual, its telling me pcb but im not sure i though I thought it would gas valve next in series? Technical help is closed for the bank holidays anyone able to offer some advice in the mean time?
    Thanks Ben.
    uɐɯ sɐƃ moderator
    gas man's Avatar
    maesteg,south wales
    13,316
    Default Re: Britony combi se
    have you checked, ventures,tubing,ignition cartridge/spark generator?
  3. GASMAN
    IMPOR
    Sep 2010
    Cardiff
    492
    Does solinoid on gas valve click.
    the tubing seemed intact, im no longer with the boiler so cant check on anything right now. The fan seems to run to approx 2-3 secs before cutting out. If it were the spark generator i would imagine it would run for longer as im guessing it wouldnt recognise the fault that soon. There is no click on the gas valve, if it were the gas valve would it cut the fan out that quick or would the ignition process continue a bit longer?
  1. Britony Combi SE 80 problem.....
    By Ian Billingham in forum Central Heating Forum
    Last Post: 27-11-2010, 08:52 PM
  2. britony combi 80 se
    By chamberfive in forum Central Heating Forum
    Last Post: 16-10-2010, 09:21 PM
  3. Chaffateux britony combi se
    By Plumbcrazy56 in forum Gas Safe Register Forum - Public Forum
    Last Post: 15-10-2010, 01:13 PM
  4. Britony Combi 80 SE. Help please.
    By Mick Stupp in forum Plumbing Forum
    Last Post: 13-07-2010, 11:29 PM
  5. Britony combi se boiler
    By BR111 in forum Central Heating Forum
    Last Post: 29-03-2010, 09:05 PM
britony combi se 80 no flame detection
britony combi se no flame detected
britony combi se
flame not detected on britony se combi boilerbitony combi 80se pcbbrittony combi sebritony combi se not igniting
