Results 1 to 12 of 14
Plumbing & Plumbers Forum - no hot water or heating
Discuss no hot water or heating in the Central Heating Forum at Plumbers Forums; Hi. Boiler stopped working. Fault light indicates, blocked condensate drain or flame failure. Its not the condensate drain, as iv disconected it and still wont work. The boiler kicks in ...
    Sep 2010
    163
    Default no hot water or heating
    Hi. Boiler stopped working. Fault light indicates, blocked condensate drain or flame failure. Its not the condensate drain, as iv disconected it and still wont work. The boiler kicks in for 10 seconds, stops and starts a few times then the fault light comes on. Any ideas????
    Sep 2010
    Cardiff
    492
    Default Re: no hot water or heating
    Hi Brasso
    Would help to know what boiler it is. Try spinning the pump.
    uɐɯ sɐƃ moderator
    gas man's Avatar
    maesteg,south wales
    13,564
    as said what make?
    GASMAN
    IMPOR
    Sep 2010
    163
    Baco combi 105he. How do I spin the pump?
    uɐɯ sɐƃ moderator
    gas man's Avatar
    maesteg,south wales
    13,564
    could be aps at fault you really need a gsr engineer
    GASMAN
    IMPOR
    Sep 2010
    Cardiff
    492
    When you say the boiler kicks in, do you mean it actually lights.
    Sep 2010
    163
    Sorry baxi not baco. Yes it fires up then stopsand starts a few times
    Sep 2010
    Cardiff
    492
    When running hot water only (heating off) does the same happen, or does it not fire up
    uɐɯ sɐƃ moderator
    gas man's Avatar
    maesteg,south wales
    13,564
    aps would be my first guess,replaced loads doing this fault
    GASMAN
    IMPOR
  10. The Following User Says Thank You to gas man For This Useful Post:
    brasso1981 (27-12-2010)
    Sep 2010
    163
    Its just started working again. Could the flue have froze up? The temperature outside has risen to the tropical highs of plus 3. What's the aps gasman?
    uɐɯ sɐƃ moderator
    gas man's Avatar
    maesteg,south wales
    13,564
    aps>air pressure switch ,flue very unlikely to freeze up as flue stat would have to be re set for it to start working
    GASMAN
    IMPOR
  13. #12
    Sep 2010
    Cardiff
    492
    LOL. Tropical temps? Where you at. Freezing here. Glad its going, probably needs service.
    APS is air presure switch.
  1. Replacing central heating and water heating - advice please
    By sylan in forum Central Heating Forum
    Last Post: 03-01-2011, 07:13 PM
  2. Heating only comes on with the hot water!!
    By ava256 in forum Central Heating Forum
    Last Post: 15-12-2010, 02:48 PM
  3. Central Heating only working when hot water heating.
    By MickBrown in forum Central Heating Forum
    Last Post: 05-11-2010, 06:29 PM
  4. No heating unless water is heating
    By unwaith in forum Central Heating Forum
    Last Post: 13-10-2010, 05:56 PM
  5. hot water not heating but central heating working???
    By bigd111 in forum Plumbing Forum
    Last Post: 09-04-2009, 03:58 PM
flame failure or blocked condensate drain
ukplumbersforums.co.uk air pressure switch testing on a baxi 105he
baxi combi 105 he flame failure or blocked condensate drain
baxi combi 105 he condensate drain blocked
baxi combi 105 he blocked condensate drain
