Results 1 to 15 of 32
Plumbing & Plumbers Forum - System only get Warm at best!
Discuss System only get Warm at best! in the Central Heating Forum at Plumbers Forums; OK folks, I am really struggling with this one and it would seem my plumber is as well, so here goes the catalogue of events to date: 1. Back in ...-
26-12-2010 #1New to Plumbing Forum
- Dec 2010
- 13
OK folks,
1. Back in the summer I upgraded my ancient boiler to a modern worcester greenstar, no obvious problems at the time as I was only running the hot water. At that time the system was power flushed and after 20 years there was a lot of sludge removed.
2. Fast forward to Winter when I start to use the heating I notice that at best the radiators are only warm even after all the usual bleeding etc
3. Plumber notices that the "on" light for the burner is no on as often as it should and reckons there might be a circulation problem, ie the hot water is not getting away from the boiler and the stat in the boiler is causing it to shut off, so the as the circulating pump is also ancient we replace that.
4. Still no significant improvement and I notice that the hot water isn't really as hot as it should be either, so the system is powerflushed again, more sludge removed, though obviously not as much as first time.
5. I fit a magnaclean to the system to keep taking out any residual sludge
6. Still not getting the temps, so plumber converts the system from an open (header tank) to a closed pressurised system.
7. Now with the new boiler, new pump, 2 X Powerflushed system and closed system, the radiators should be able to get so hot that you cant touch them, but even with the boiler stat turned up full they are best only warm and hot water could be hotter.
Suffice to say, I am starting to despair, so any thoughts would be appreciated
regards
26-12-2010 #2Plumbers Arms member
- Sep 2009
- South Yorkshire
- 2,436
- 48
- Thanked 205 Times in 199 Posts
Re: System only get Warm at best!
Where do you live as some one will need to look at this to sort your problems
That is some one who knows what they are doing (no offense)
26-12-2010 #3Steady Plumbing Forum Contributor
- Jul 2010
- hants
- 232
- 7
- Thanked 26 Times in 25 Posts
does boiler get up to temp itself ie between 70 and 82 degrees , if so check bypass , could be open too far causing short circuit , if so it needs shutting then resetting
46
26-12-2010 #4New to Plumbing Forum
- Dec 2010
- 13
Hi Guys,
Thanks for replies, in order
1. I live in the North of Scotland
2. I dont have a thermocouple to measure actual temps, but when running, the outlet water pipe on the boiler gets to the sort of temps, I would expect the radiators to be sitting at
Cheers
26-12-2010 #5
do any rads at all get up to temp?
26-12-2010 #6New to Plumbing Forum
- Dec 2010
- 13
The ones at one end of the house do a get a bitter hotter, though not so hot as you cant your hold your hand on them, ones furthest away only luke warm. If the "hotter" ones were really hot, I would figure on a bit of balancing being the problem, but even the ones at the hot I would only classify as warm.
Its almost as if there was still a blockage in the system, but after 2 power flushes, i would have thought that would have been sufficient to clear most of the sludge out. Incidentally there only 10 radiators in the system.
26-12-2010 #7Plumbers Arms member
- Oct 2010
- 1,654
- Thanked 81 Times in 81 Posts
it sounds like a circulation problem if the boiler is getting up to temperature , I would follow the pipe and see where it turns cold and check these is no isolation valve part closed
26-12-2010 #8New to Plumbing Forum
- Dec 2010
- 13
The pipes appear to be quite hot after they leave the pump and go down under the floor and there are no isolation valves under the floor, so unless there is some sludge/blockage that the power flushing did not remove?
26-12-2010 #9Plumbers Arms member
- Oct 2010
- 1,654
i have seen a one way valve partially blocked before ,it was a right nightmare ,i suppose you could try turning the pump around you could also have a problem on the diverter valve not opening fully
26-12-2010 #10New to Plumbing Forum
- Dec 2010
- 13
Downstream of the control valves also appears to be very hot, but for whatever reason. just not seeing same level of heat in radiators
26-12-2010 #11
you could try flushing them out manually
26-12-2010 #12New to Plumbing Forum
- Dec 2010
- 13
May have to resort to this, was hoping to avoid if possible. Anyone any experience with vibraclean as an alternative to pulling the radiators?
26-12-2010 #13Plumbers Arms member
- Oct 2010
- 1,654
rubber mallet does the job , might be worth changing the oldest and worse rad,or as above
26-12-2010 #14Plumbing Forum Contributor
- Feb 2010
- 53
- Thanked 9 Times in 8 Posts
I had a similar problem - I found that the plumber had fitted an ordinary valve between supply & return pipes, instead of directional PRV... it was opened very slightly, which resulted in hot water supply instantly going to return pipe & back into the boiler - virtually no heat anywhere else.
Feel your return pipe (close to the boiler - be careful you don't burn yourself), if very hot - get the plumber back to replace valve.
referring to a directional PRV (if fitted), could be stuck open.Last edited by JimH; 26-12-2010 at 02:53 PM.
26-12-2010 #15New to Plumbing Forum
- Dec 2010
- 13
Hi JimH,
Definitely got a PRV fitted as opposed to standard valve and retun pipe to particularly warm, so I dont believe its passing. I still think its some crap stuck somewhere in the system, but finding it is the problem!
Radiators not warm as they were
By soneill657 in forum Central Heating ForumReplies: 2Last Post: 01-12-2010, 01:36 PM -
Unused Warm Air Heating System
By ginnes in forum Central Heating ForumReplies: 2Last Post: 17-08-2010, 06:19 PM -
Warm air
By mike_s in forum Gas Safe Register Forum - Public ForumReplies: 12Last Post: 07-07-2010, 04:45 PM -
warm water
By sh3p69 in forum Central Heating ForumReplies: 10Last Post: 08-02-2010, 09:46 AM -
warm welcome
By rocketman in forum New Member IntroductionsReplies: 2Last Post: 09-10-2009, 12:08 AM
Cost to remove old electric...
16 Minutes Ago in Plumbing Forum
