Results 1 to 8 of 8
Plumbing & Plumbers Forum - Glow-worm hideaway boiler 70b/80b
Discuss Glow-worm hideaway boiler 70b/80b in the Central Heating Forum at Plumbers Forums; Hi, got one of these boilers, seems very innefficient the amount of heat going out through the flue to the outside seems way more than acceptable. The amount of gas ...-
26-12-2010 #1New to Plumbing Forum
- Dec 2010
- 3
The amount of gas used each day (on twice,for about 9 hours in total) is around 18/20 numerals on the meter.
Question is, is the boiler faulty (its about 20 yrs old) or just normal for that type of boiler?
Cheers
26-12-2010 #2Plumbers Arms member
- Oct 2010
- 1,654
- Thanked 81 Times in 81 Posts
Re: Glow-worm hideaway boiler 70b/80b
well if you are getting a nice blue flame and you know doubt have it serviced every year I cannot see the problem since we are having the coldest snap in 20 years, i would recommend getting a CO detector also
27-12-2010 #3New to Plumbing Forum
- Dec 2010
- 3
27-12-2010 #4uɐɯ sɐƃ moderator
- Jan 2010
- maesteg,south wales
- 13,567
- 836
- Thanked 1,284 Times in 1,225 Posts
if this is a balanced flue as i am assuming it is as you say you can touch the flue,it should have a guard around it and yes it is normal to get very hot your boilers not very efficient but look on the plus side theres no condensate pipe to freeze,if your concerned about your boiler call out a gsr engineer
GASMAN
27-12-2010 #5Plumbers Arms member
- Oct 2010
- 1,654
agree with above ,but i regret taking mine out as it use to keep the kitchen nice and warm and great for drying the clothes
27-12-2010 #6UK Plumbersforums Trusted Advisor.
- east london
- 6,753
- 9
- Thanked 387 Times in 375 Posts
i can guarantee that the boiler you replace it with wil not last as long and will breakdown a lot more
27-12-2010 #7New to Plumbing Forum
- Dec 2010
- 3
28-12-2010 #8Plumbers Arms member
- Oct 2010
- 1,654
the only problem I ever had was replacing the thermocouple and eventually having a water leak from the heat exchanger, so i replaced it with a broag remeha 2.5 years old starts leaking water from the diverter valve fortunately got a warranty call guy comes out and hasnt parts ,then I had to wait 2 weeks for guy to come back ,mean while leaving 2 buckets under boiler, guy arrives and replaces diverter valve ,sychron motor,clip, happy days , 3 days late leak starts again condensation pipe frozen , to be honest the old one was better in some ways
Glow worm Boiler Air lock
By Livvid in forum Plumbing ForumReplies: 3Last Post: 12-10-2010, 08:33 PM -
Glow Worm Fuelsaver Mk 2 / 40B Boiler
By fatowl in forum Plumbing ForumReplies: 2Last Post: 19-09-2010, 12:24 AM
SIAMP Skipper 45 Flush Problem
9 Minutes Ago in Plumbing Forum
