Plumbing & Plumbers Forum - another ferroli andother fault?
Discuss another ferroli andother fault? in the Central Heating Forum at Plumbers Forums; hi anyone got any ideas. ferroil f24 combi pressure drops about 1/2 bar in an 12 hour period. have check PRV & expansion vessel. Have checked rad - all ok. ...
    Plumbing Forum Contributor
    South East
    96
    Default another ferroli andother fault?
    have check PRV & expansion vessel. Have checked rad - all ok. cant see and visable leak though some pipework does disapear?
    anyone got any ideas or have a similar prob? was going to put some leak sealer in system?
    villa_tom's Avatar
    Sep 2010
    The Midlands
    3,547
    Default Re: another ferroli andother fault?
    I'd go with the leak sealer, Its good stuff and only about 12 quid so if it doesn't work then you've not lost out on much.
  3. If you could read my mind I'd get punched in the face a lot
  4. The Following User Says Thank You to villa_tom For This Useful Post:
    mkflow (23-12-2010)
  5. #3
    uɐɯ sɐƃ moderator
    gas man's Avatar
    maesteg,south wales
    13,564
    this boiler has a tendency to eat recuperaters check the condensate connection for water after its been off for several hours,leak sealer wont help
    GASMAN
    IMPOR
  6. #4
    South East
    96
    recuperater?? what is that
  7. #5
    uɐɯ sɐƃ moderator
    gas man's Avatar
    maesteg,south wales
    13,564
    hang on its not a condenser? my mistake on a band b boiler the condensing heat exchanger is refereed to as a recuperater so if this was a f24b it would be suspect as they are weak
    GASMAN
    IMPOR
  8. #6
    South East
    96
    ok thanks gas man was bit worried there!
    that boiler is still slowly leaking somewhere have put leak sealer in and still dropping
  9. #7
    Jan 2011
    Hi when you say you checked the pressure vessel, did you mean for leaks, or pressure? These have a common fault in that they tend to loose there internal pressure, which leaves no room for expansion, so when the boiler heats up it lets out the excess (expanded) water through the safety valve, then overnight when the water cools down again the pressure drops to below the minimum operating pressure.
    If you havent checked it, do the following:
    Turn of the two heating flow and return taps underneath the boiler, drain the water from within the boiler, either using the little black philips head drain point next to the right hand heating pipe connection, or loosen the heating pipe connector from the Bottom of the boiler (NOT the copper pipe nut, the nut on the valve elbow that connects to the boiler). Once empty, remove the pipe from the bottom of the expansion vessel, then connect a small car footpump to the presure valve (looks like a car tyre valve with a dust cap on it) on the top of the vessel, it should be 1 bar (14.5 Psi) pressure. If not, pump it up gently to the correct pressure, then reconnect the pipe, close the drain tap, or do up the pipe nut underneath the boiler, open the two isolating valves and top up the system to about 1 - 1.5 bar on the pressure guage.
    Run it for a couple of days and see what happens.
    The valaves usually fail on the top of the pressure/expansion vessels and slowly leak out the air, like a tyre going falt, so expect the problem to return in a few months. If it does, you'll need a new expansion vessel.
    Hope some of that helps,
    Andy.
  1. Ferroli Optimax 38, nothing on display? Possible PCB fault?
    By alexfossa in forum Central Heating Forum
    Last Post: 22-08-2011, 11:02 AM
ferroli f24 fault finding
ferroli f24 expansion vessel
ferroli f24 fault codes
ferroli f24
ferroli f24 losing pressure
ferroli f24 heat exchanger
ferroli boiler losing pressure overnight
