Results 1 to 13 of 13
Plumbing & Plumbers Forum - Condensate Pipe Advice
Discuss Condensate Pipe Advice in the Central Heating Forum at Plumbers Forums; Hi All, I have an Ariston ACO 32 MFFI condensing boiler that is losing pressure. Engineer has looked at it several times without resolving the issue. Proved it's not the ...
    Default Condensate Pipe Advice
    Hi All, I have an Ariston ACO 32 MFFI condensing boiler that is losing pressure. Engineer has looked at it several times without resolving the issue. Proved it's not the Prv and he has changed the condensate trap. I informed him that the condensate pipe drips whether the boiler is running or not. Even if the boiler has been off all night the condensate drips every 5-10 secs. He said the boiler has to be off for days. Unable to prove this as it's Baltic outside. Is he right or not wanting to do repair under warranty. Any advice appreciated.
    Plumbing Forum Contributor
    Feb 2010
    53
    Default Re: Condensate Pipe Advice
    I'm sure the experts here will help you Stevie. You don't say wheather your pipework, radiators etc have been checked for leaks... they'll need that infomation? As for the condensate water constantly dripping, even when off all night... I would doubt it, at least, I know mine doesn't? Are you sure it's coming from the condensate pipe and not the PRV overflow pipe?
  3. The Following User Says Thank You to JimH For This Useful Post:
    StevieE (21-12-2010)
    Thanks for replying. I've checked all the valves and exposed pipes and no visable signs of leaks. Considering its been losing pressure for a couple of months and getting worse any leak between the floors should be showing. The condensate pipe has flexible pipe from boiler sitting inside a tumdish so there is an air break and you can see it dripping into the White plastic pipe which runs outside down the wall and is buried. The Prv is a copper pipe. I had a plastic bag over the end of the pipe for two days and no water appeared despite losing pressure.
    Feb 2010
    53
    Sounds like you have an interal leak in the boiler or connecting pipes... if it's under warranty I'd get the engineer back.
    uɐɯ sɐƃ moderator
    gas man's Avatar
    maesteg,south wales
    13,357
    sounds to me like your main heat exchanger has failed,boiler may be a write off
    GASMAN
    IMPOR
  7. The Following User Says Thank You to gas man For This Useful Post:
  8. #6
    Feb 2010
    53
    Quote Originally Posted by gas man View Post
    I didn't wan't to be the one who said it gas man
  9. #7
    GQuigley67's Avatar
    Oct 2010
    Glasgow, Scotland
    4,696
    what do you mean failed ? I'm just curious
  10. #8
    uɐɯ sɐƃ moderator
    gas man's Avatar
    maesteg,south wales
    13,357
    its burst,the heat exchanger,system water is going down the condensate
    GASMAN
    IMPOR
  11. #9
    Thanks everyone. I phoned British Gas and because the boiler is still working they won't send an engineer till next Wednesday. I'll try to nurse it till then. Any tips on how to deal with engineer who refuses to believe the obvious.
  12. #10
    uɐɯ sɐƃ moderator
    gas man's Avatar
    maesteg,south wales
    13,357
    ask him is he blind? or stupid if the flexy section coming off the bottom of your boilers heat exchanger still drips water after its been off all night,the heat exchangers failed its quite simple
    GASMAN
    IMPOR
  13. #11
    May 2009
    northampton
    430
    The condensate has nothing to do with the pressure loss, but as gas man says, if it is dripping whilst off then either you have a leak within the boiler from a fitting/valve or the dreaded heat exchanger is popped!
  14. #12
    uɐɯ sɐƃ moderator
    gas man's Avatar
    maesteg,south wales
    13,357
    they are known to fail on the aco,its not a good boiler sadly as i found out fitted a few a couple of years back
    GASMAN
    IMPOR
  15. #13
    Hi everyone, just a quick update. The third British Gas Engineer diagnosed the heat exchanger failed within minutes of entering the property. So it's not just cowboys you have to be aware of but false and misleading advice from national companies. Heat exchanger replaced and now working fine. Thanks for the sound advice.
  1. Advice on condensate pipe
    By Jas328sport in forum Central Heating Forum
    Last Post: 27-12-2010, 07:54 PM
  2. Condensate pipe
    By kyle in forum Gas Safe Register Forum - Public Forum
    Last Post: 29-09-2010, 09:18 PM
  3. Condensate Pipe into Waste Pipe
    By ceedy in forum Central Heating Forum
    Last Post: 15-08-2010, 02:02 PM
  4. Condensate pipe
    By SRG in forum Central Heating Forum
    Last Post: 09-01-2010, 04:39 PM
  5. Tundish in condensate pipe (Glow Worm) - advice pls?
    By Raven in forum Central Heating Forum
    Last Post: 13-02-2009, 11:48 PM
condensate pipe
leaking condensate pipe
boiler condensate pipe leaking
ariston boiler aco 27 mffi losing pressurecan i join the prv and the condensate pipeariston aco leaksARISTON CONDENSATION DRIPPING BOILER
