Plumbing & Plumbers Forum - Old Worcester 24i combi boiler timer
Discuss Old Worcester 24i combi boiler timer in the Central Heating Forum at Plumbers Forums; Ive got an old Worcester 24i combi boiler with a timer built into the unit, (NOT a digital timer). The kind you have to push the little teeth in for ...-
05-12-2010 #1New to Plumbing Forum
- Dec 2010
- 14
Ive got an old Worcester 24i combi boiler with a timer built into the unit, (NOT a digital timer). The kind you have to push the little teeth in for when you want the heating to come on and off. But Im not sure if you have to push the teeth in for the whole peroid that I want the heating on or do I just push in when I want it to start then stop? Help needed please. My feeling is that they all need to be pushed in but other people are saying otherwise.
05-12-2010 #2UK Plumbersforums Trusted Advisor.
- Dec 2009
- Coatbridge, Lanarkshire
- 3,515
- 52
- Thanked 342 Times in 315 Posts
Re: Old Worcester 24i combi boiler timer
the teeth need to be in for the whole period you require the heating on, if you put 1 tooth in at 2pm and another in at 6pm the heating will come on at 2pm for 1-2 mins depending on the clock, then it will come back on again at 6pm for 1-2 mins, pushing the tooth in switches something at the back of the clock as it turns, so the teeth need to be in for the whole time period req'd, if you put the teeth in for any period and turn the clock manually you will hear the boiler lighting at the on time then shutting down at the off time, then reset the clock to the correct time, i do this to check whether the teeth need to be in or our for on times if i dont know the clock
05-12-2010 #3New to Plumbing Forum
- Dec 2010
- 14
Thats what I was thinking but people I spoke to seemed to think the opposite, but to me it makes more sense our way, also the people I spoke to are plumbers just people who have had those timers before. Thanks for your help and confirming my thoughts.
Worcester heatslave 20/50 oil combi boiler
By pippa in forum Central Heating ForumReplies: 2Last Post: 06-11-2010, 04:52 PM -
Worcester combi boiler
By SafeGasInstall in forum Central Heating ForumReplies: 10Last Post: 02-11-2010, 09:59 PM -
Worcester Greenstar Combi Si Boiler
By rodderz82 in forum Valves & TapsReplies: 3Last Post: 29-08-2010, 12:58 AM -
Worcester 24 CDi combi boiler problem
By deepatel in forum Plumbing ForumReplies: 3Last Post: 25-04-2010, 10:43 AM -
worcester greenstar 24i combi boiler
By Leoki in forum Central Heating ForumReplies: 8Last Post: 05-03-2010, 07:52 PM
Eco funding
5 Minutes Ago in Central Heating Forum
