Plumbing & Plumbers Forum - 2 Rads not working...
Discuss 2 Rads not working... in the Central Heating Forum at Plumbers Forums; Hi all, I am having a problem with 2 radiators in a house not working at all. I have taken the rads off the wall and opened up the valves ...
    Default 2 Rads not working...
    Hi all,
    I am having a problem with 2 radiators in a house not working at all. I have taken the rads off the wall and opened up the valves via a hose pipe and there is water coming out all valves. The water is clear.
    When I put the radiators back on the wall, they are only briefly hot with the water I use to fill them back up with, then they run cold.
    I have shut down all the other rads in the house and they still do not get warm.
    The only thing I can this it could be is that, they have been piped up wrong, eg with to flows, but I am told that they use to work fine.
    They are tall, thin modern rads and not your conventional radiator.
    The house was powerflushed by Brittish Gas 2 years ago.
    Any ideas what it could be?
    Plumbers Arms member mrlennie's Avatar
    Dec 2009
    417
    Default Re: 2 Rads not working...
    Sure its not the rad valves stuck?
    Thing is, when you take rad off and open rad valves, water comes out of both valves at a decent flow rate.
    Going to go back and try changing the valves to see if for some reason they are not 2 way valves, although rads use to work with these same valves.
    Failing that, will connect the mains onto the rad valves to try to blast out anything., although i'm really clutching at straws now.
    Dec 2009
    417
    mmm sorry yes i didn't read your post properly....
    have you taken them out and put a hose pipe through them to check flow through the rad? See if anythings gunked inside?
    steveb's Avatar
    Nov 2007
    hythe hampshire
    8,983
    my thoughts as well could be gunked up rad channels.
  1. 3 rads not working - rest are fine
    By ian99 in forum Plumbing Forum
    Last Post: 02-12-2010, 12:57 PM
  2. 2 rads not working
    By marsaday in forum Central Heating Forum
    Last Post: 05-11-2010, 08:41 AM
  3. rads upstairs not working
    By bedspoolplayer in forum Central Heating Forum
    Last Post: 07-08-2010, 08:06 PM
  4. My rads are not working properly
    By hiretools in forum Plumbing Forum
    Last Post: 24-02-2010, 07:21 PM
  5. Rads not working
    By hurst1978 in forum Plumbing Forum
    Last Post: 19-01-2010, 06:01 PM
