Results 1 to 10 of 10
Plumbing & Plumbers Forum - y-plan new motorised valve fitted - not firing up
Discuss y-plan new motorised valve fitted - not firing up in the Central Heating Forum at Plumbers Forums; as title says..... its a floor standing ideal mexico - the 3 port mid position valve was fitted today and now the boiler isnt calling for heat - the pump ...
    moony's Avatar
    Oct 2009
    1,210
    Default y-plan new motorised valve fitted - not firing up
    as title says.....
    its a floor standing ideal mexico - the 3 port mid position valve was fitted today and now the boiler isnt calling for heat - the pump runs, put me in front of a boiler or combi and im fine - but put me in front of a s-plan or y-plan wiring and i'm scratching my head - im due back there tonight - so any pointers or what to look for would be massively appreciated
    now i dont know if this was an existing problem or a new one since the motorised valve has been changed - new body new head and all wires gone back to the same way as before.
  2. www.q-plumb.co.uk for all your plumbing needs
  3. #2
    CES
    CES is offline
    CES's Avatar
    Sep 2010
    Livingston
    2,294
    Default Re: y-plan new motorised valve fitted - not firing up
    I assume you have put all the thermostats up to max? Cylinder, Room and the boiler? Check for a supply to the boiler..
    shorticus's Avatar
    Havering
    377
    This is odd. If the wiring has been done according to honeywell's schematics then the pump and the boiler should both have a live from junction 8 in the terminal box, this is fed from the orange wire from the valve, i.e. if the pumps live then the boiler should be too
    shorticus's Avatar
    Havering
    377
    sorry didn't mean to confuse things, what I meant was if the pump is live then there should be a signal live being sent to the boiler, I believe that the mexico also needs a permanent live
  6. The Following User Says Thank You to shorticus For This Useful Post:
    moony (03-12-2010)
  7. #5
    north west
    437
    on of the engineers on here has put a wiring diagram up so look for the post and its on it
  8. The Following User Says Thank You to metaldust9 For This Useful Post:
    moony (03-12-2010)
  9. #6
    moony's Avatar
    Oct 2009
    1,210
    Quote Originally Posted by CES View Post
    im not that bad haha - yeah done that pal
  10. #7
    CES
    CES is offline
    CES's Avatar
    Sep 2010
    Livingston
    2,294
    Just a thought, what model is the mexico? There is a down draught overheat stat fitted to some of them, fitted in series with the control stat. It could be holding it off?
  11. #8
    CES
    CES is offline
    CES's Avatar
    Sep 2010
    Livingston
    2,294
    Quote Originally Posted by moony View Post
    I didnt mean to be cheeky btw! no offense meant!
  12. #9
    moony's Avatar
    Oct 2009
    1,210
    no worrys - sorted now was a clogged up system and i mean clogged!
  13. The Following User Says Thank You to moony For This Useful Post:
    shorticus (05-12-2010)
  14. #10
    shorticus's Avatar
    Havering
    377
    good to hear you sorted it, must've been quite satisfying
  1. Motorised valve
    By slug in forum Plumbing Forum
    Last Post: 26-09-2010, 09:13 PM
  2. siemans motorised valve
    By wilks121 in forum Central Heating Forum
    Last Post: 02-05-2010, 12:05 PM
  3. 3 way motorised valve
    By tommo in forum Central Heating Forum
    Last Post: 28-04-2010, 09:33 PM
  4. Y plan motorised valve problem
    By steveboy in forum Plumbing Forum
    Last Post: 10-12-2009, 02:37 PM
  5. Honeywell 3 Way Motorised Valve.
    By Jim Cooper in forum Valves & Taps
    Last Post: 04-12-2009, 11:36 PM
y plan not working
setup wiring for y plan boiler not firing up
y plan pump not running
y plan not firing up wiring or valve
schematic for fitting 3 way motorised central heating valve
