Plumbing & Plumbers Forum - Combi Boiler Install Flow Rates/Pressures
Discuss Combi Boiler Install Flow Rates/Pressures in the Central Heating Forum at Plumbers Forums; Hi all, Again, after some advice from someone with more experience than I. I'm considering a 39KW combi boiler install at a customer's property. I measured static mains pressure at ...-
03-12-2010 #1Plumbers Arms member
- Lincoln, Lincolnshire
- 958
- 71
- Thanked 53 Times in 48 Posts
Hi all,
Again, after some advice from someone with more experience than I. I'm considering a 39KW combi boiler install at a customer's property. I measured static mains pressure at 3.25 bars this afternoon. This dropped to 3 bars when I opened a tap in their loft conversion which is also mains fed.
The flow rate from the kitchen tap is 15l/min but this is coming in through a flexi-hose underneath which is obviously reducing the bore below the 15mm on the incoming mains.
The boiler I am thinking of is the Broag Remaha Avanta Plus 39KW which has a hot water flow rate of 16l/min. I think these flow rates and pressures are more than adequate to run this boiler. Does anyone disasgree or have any further advice to share?
I've installed a few of these boilers but tbh this is the first time I've done more than a visual examination of flow rates and pressures.
03-12-2010 #2Plumbers Arms member
- 958
- 71
Re: Combi Boiler Install Flow Rates/Pressures
bump..
03-12-2010 #3Plumbers Arms member
- Jul 2010
- West Lancashire
- 751
- 133
- Thanked 71 Times in 66 Posts
Here we go again - big combi with high capacity hot water flow rates - IF THE MAINS SUPPLY IS UP TO IT - and at all times of the year. When its cold the temp lift is going to reduce the flow rate and in the summer because everyone without a meter is watering their garden all day and night pressure will drop - esp on a loft conversion. Combis are only for flats and small houses as a space saving alternative to conventional systems.
If a domestic dwelling has more than 3/4 people in it with more than 1 ensuite just forget it and
install a proper system.
week after week this forum has all sorts of people posting about concerns and problems like this.
centralheatking
Flow rates!
By NellyC in forum Central Heating ForumReplies: 17Last Post: 29-05-2010, 10:06 PM -
Help!!! how to find out air flow rates!!!
By mutley racers in forum Central Heating ForumReplies: 2Last Post: 17-05-2010, 07:15 PM -
flow rates for pipe
By buffy27 in forum Plumbing ForumReplies: 1Last Post: 18-02-2010, 06:56 PM -
Low flow rates
By RogerS in forum Plumbing ForumReplies: 8Last Post: 12-01-2010, 05:28 PM -
Combi Boiler Sizing/Flow Rates
By woodbine in forum Plumbing ForumReplies: 1Last Post: 11-09-2009, 11:02 PM
Keston C55
1 Minute Ago in Central Heating Forum
