Results 1 to 6 of 6
Plumbing & Plumbers Forum - Honeywell 3 port valve Problems!!
Discuss Honeywell 3 port valve Problems!! in the Central Heating Forum at Plumbers Forums; Problem is I can only get heating, when tank stat is calling for hot water. I've got a Baxi Solo, with Drayton controller, and Honeywell room and tank stats, and ...
    Default Honeywell 3 port valve Problems!!
    Problem is I can only get heating, when tank stat is calling for hot water. I've got a Baxi Solo, with Drayton controller, and Honeywell room and tank stats, and a Honeywell mid position 3 port valve. Thought the valve may be sticking, so removed the head, and the valve with pliers moves freely. when moved over makes no difference, to heating or not. Voltage to room stat ok. Voltages at 3 port as follows.
    ch+hw on White 234v Green 51v Orange 237v.
    ch+hw off W 3v G 240V O 77v.
    Hw only on. W 5.7v G 240v O 77v.
    Ch only on. W 240v G240v O 80v.
    Motor on head seems to move when not attached to valve body.
    It's freezing, and i'm fed up drawing off hot water every hour or two, to fire up my heating system. Help Please!!!!!!!!! Thanks in advance. Greg
    uɐɯ sɐƃ moderator
    gas man's Avatar
    maesteg,south wales
    13,350
    Default Re: Honeywell 3 port valve Problems!!
    call in a pro mate your valve has died
  3. GASMAN
    IMPOR
    Aug 2009
    1,109
    Quote Originally Posted by haydencookdonna View Post
    Presumably you mean Grey, not Green.
    The actuator is faulty - that's the box on top of the valve.
    You can replace the actuator on its own. Cut the cable without disconnecting the wires, then you will know where they go when fitting the new actuator.
    Any plumber's merchant will stock the actuator.
    Yes Sorry! I meant Grey and not green. If the actuator is faulty, why does removing it and moving the valve with pliers manually not ake a difference? Thanks. Greg
    Sep 2010
    53
    according to honeywell site faultfinding guide on mid position y plan
    suspect the v4073a valve is faulty only if the valve does not operate as specified in the following checks.
    Valve open for heating only
    procedure
    switch off mains supply.
    disconnect grey and white wires from appropriate junction box terminals.
    reconnect both grey and white wires to permanent live in junction box.
    switch on mains supply,
    valve motor should now move to fully open heating port A.
    the motor should stop automatically when port A is open, and stay in this position as long as power is applied to white and grey wires.
    when port A is fully open , the orange wire becomes live, to start pump and boiler.
    double check by feeling that port A is getting progressively warmer.
    hope this helps as although fully qualified sparks and done a honeywell course ive still to get to grips with these plans as i do not get to work on them often cheers
    Aug 2009
    1,109
    If the actuator is faulty, why does removing it and moving the valve with pliers manually not make a difference?
    You said that all you can get is heating when the tank stat is calling.
    A quick explanation:
    HW only - boiler lit from cylinder thermostat Call terminal
    HW and CH - boiler lit from cylinder thermostat Call terminal
    CH only - boiler lit from orange wire
    You will find that there are three wires to the same terminal: Cyl Stat Call, Valve Orange and Boiler ON.
    The reason you can only have CH with HW is that the voltage on the orange is only 80V, which is not sufficient. The solution is a new actuator.
  1. 3 port and two port valve in same system
    By john the driver in forum Central Heating Forum
    Last Post: 31-12-2010, 11:02 AM
  2. honeywell 3 port valve problem ARGHH!!!!!!!!!
    By haydencookdonna in forum Plumbing Forum
    Last Post: 26-11-2010, 07:43 PM
  3. Honeywell 3-port valve needs replacing...
    Last Post: 29-09-2010, 08:46 AM
  4. Honeywell 3 Port Diverter Valve problems
    By Paul Sharples in forum Central Heating Forum
    Last Post: 11-09-2010, 12:45 PM
  5. Siemens two port valve problems!
    By sasik in forum Central Heating Forum
    Last Post: 22-02-2009, 01:17 PM
honeywell 3 port valve actuator
honeywell 3 port valve problems
honeywell 3 way valve actuator
three port valve faults3 port valve fault finding
