Plumbing & Plumbers Forum - Performa 28. CH working but no Hot Water!!
Discuss Performa 28. CH working but no Hot Water!! in the Central Heating Forum at Plumbers Forums; Hi all, hoping someone can offer some advice. And hopefully I've created this thread in the correct place. I have a Performa 28 boiler. It's been working fine (the hot ...
    Default Performa 28. CH working but no Hot Water!!
    I have a Performa 28 boiler. It's been working fine (the hot water used to take a little while to come through but it always came through eventually), but as of Monday I now have no hot water coming through the taps at all.
    The central heating is working fine. On the boiler itself the power light is green, the radiator light is green, the burner light goes on and off (yellow) which I'm guessing it's supposed to, but the water light is just off all the time, regardless of whether I put the boiler on hot water only, or hot water + radiators.
    If anyone had any suggestions as to what the problem may be, or how I might go about successfully identifying the problem I'd be eternally grateful! I live in the North East and we're currently facing ridiculous amounts of snow and cold weather so it could have hardly happened at a more inopportune Monet
    Oct 2010
    1,654
    Default Re: Performa 28. CH working but no Hot Water!!
    the pipe could be frozen
    If the pipe was frozen wouldn't that mean there should be no water coming through at all?
    The hot water pressure is as it always is and the flow is fine, just it's ice cold
    Oct 2010
    1,654
    correct ,the boiler does not sense you have opened the tap this could be a worn diaphram
  5. The Following User Says Thank You to gasmarc For This Useful Post:
    dh82 (30-11-2010)
    If it was the diaphragm, how easy/expensive are these to replce?
    Is it a job I would need to call a Heating Engineer in for?
    Oct 2010
    1,654
    it depends on how clued up you are personally i would think its a heating engineers job
    Jun 2010
    698
    Sounds like diaphragm, often you notice the water running faster thro the hot taps as they get cooler & eventually the boiler doesn't fire. A simple job for a GS engineer.
    If not dia then Dhw ntc needs to be checked aswell as changeover/divertor valve operation & maybe plate heat Exchanger
  1. Potterton Performa 28 No hot water
    By yardicus in forum Gas Safe Register Forum - Public Forum
    Last Post: 21-05-2010, 06:58 PM
  2. Tap full on for Hot water Potterton Performa 28
    By lewmal in forum Central Heating Forum
    Last Post: 01-09-2009, 04:15 PM
  3. hot water cutting out! performa 28
    By berthollywood in forum Central Heating Forum
    Last Post: 27-06-2008, 06:35 PM
performa 28 no hot water
no hot water but ch ok
cold weather no hot water but central heating ok
plumbing heating working but no hot water
central heating working but no water cold weather
potterton performa 28 water cold
