Results 1 to 4 of 4
Plumbing & Plumbers Forum - faulty pipie stat?
faulty pipie stat?
Discuss faulty pipie stat? in the Central Heating Forum at Plumbers Forums; got a pipe stat that clicks on once frost stat signals but does not switch off? any one got any ideas. i think it is def wired up wrong as ...-
29-11-2010 #1Plumbing Forum Contributor
- Oct 2009
- s/east
- 58
- 3
- Thanked 2 Times in 2 Posts
faulty pipie stat?
got a pipe stat that clicks on once frost stat signals but does not switch off? any one got any ideas. i think it is def wired up wrong as connected to white wire (from 3p.v) in junction
29-11-2010 #2UK Plumbersforums Trusted Advisor.
- Apr 2010
- Scotland
- 9,348
- 281
- Thanked 1,177 Times in 1,044 Posts
Re: faulty pipie stat?
Is the pipe heating up?
29-11-2010 #3Plumbing Forum Contributor
- Oct 2009
- s/east
- 58
- 3
yeah boiler switches on dont when get to pipe stat temp set around 15-20 just dont switch off
29-11-2010 #4UK Plumbersforums Trusted Advisor.
- Apr 2010
- Scotland
- 9,348
- 281
Test the stat using a multimeter. If ok it is the wiring.
If you have 2 motorised valves it should be wired permanent live - frost stat - pipe stat - orange of the valves.
Mid position valve, perm live - frost stat - pipe stat - white of valve.
No valves, perm live - frost stat - pipe stat - switched live.
Frost stat should be set to around 5 deg and pipe stat fitted on the return set to around 25 deg.
Existing room stat with wireless programmer and stat?
By p0bber in forum Central Heating ForumReplies: 2Last Post: 08-11-2010, 10:20 PM -
Can a faulty faulty tap cause low water pressure.
By Nas in forum Plumbing ForumReplies: 2Last Post: 28-09-2010, 10:30 AM -
Faulty boiler
By Connor Williams in forum Plumbing ForumReplies: 3Last Post: 14-10-2009, 10:57 PM -
Faulty dishwasher
By Connor Williams in forum Plumbing ForumReplies: 1Last Post: 03-10-2009, 05:33 PM -
faulty gas meter
By shortyboy in forum Plumbing ForumReplies: 0Last Post: 03-05-2008, 08:54 PM
compression fitting blew off...
4 Minutes Ago in Plumbing Forum
