Results 1 to 13 of 13
Plumbing & Plumbers Forum - faulty valve on performa 24
Discuss faulty valve on performa 24 in the Central Heating Forum at Plumbers Forums; hi all. got a faulty divertor (i think) on a potterton performa 24. The valve switch makes at front of valve but the switch on top is slightly to short. ...
    Plumbing Forum Contributor
    Oct 2009
    s/east
    58
    Default faulty valve on performa 24
    The valve switch makes at front of valve but the switch on top is slightly to short. if pushed with screw driver the boiler fires. does this mean a new divertor valve or diaphram??
    many thanks
    uɐɯ sɐƃ moderator
    gas man's Avatar
    maesteg,south wales
    13,319
    Default Re: faulty valve on performa 24
    remove the small diaprahm you will either find a blocked orifice in the body,or faulty diaprahm does NOT require a new valve
  3. GASMAN
    IMPOR
    Oct 2009
    s/east
    58
    many thanks gas man.
    what is going rate for this?
    Banned
    Jul 2009
    North Devon
    1,889
    Bout £300 if I have to drive upto to you old son. depends on your area tho, anywhere from £55 for a callout and parts extra going up
    uɐɯ sɐƃ moderator
    gas man's Avatar
    maesteg,south wales
    13,319
    between £45-£ 85 plus parts at £5-£10
    GASMAN
    IMPOR
    Oct 2009
    s/east
    58
    lol
    many thanks. i aint too hot on breakdowns as mainly do installs
    uɐɯ sɐƃ moderator
    gas man's Avatar
    maesteg,south wales
    13,319
    right well your about to learn,drain the heating via a doc,isolate elecs,remove rear microswitch,remove lh side panel,remove 4x slot screws on the flow switch houseing,carefull not to lose spring/plunger,remove diaprahm look for wear/holes,check small orifice under the diaprahm for blockages use a needle or similar,fit new diaprahm and re-assemble but before you do this make absolutely sure the pump has not gone as you will get the same symptoms
    GASMAN
    IMPOR
  9. The Following User Says Thank You to gas man For This Useful Post:
    everflow09 (29-11-2010)
  10. #8
    Oct 2009
    s/east
    58
    Have i got to drain the whole system cant i isolate valves under boiler
  11. #9
    uɐɯ sɐƃ moderator
    gas man's Avatar
    maesteg,south wales
    13,319
    you can and drain via the white drain off,forgot to mention theres small hydrolic pipe to undo as well,this repair would take about an hour to do but allow a bit longer if unfamiliar with the boiler
    GASMAN
    IMPOR
  12. #10
    Oct 2009
    s/east
    58
    That hdolic pipie would be in in front of the valve?
  13. #11
    uɐɯ sɐƃ moderator
    gas man's Avatar
    maesteg,south wales
    13,319
    no back,think a 8mm spanner fits
    GASMAN
    IMPOR
  14. The Following User Says Thank You to gas man For This Useful Post:
  15. #12
    Oct 2009
    s/east
    58
    MANY THANKS
    will let you know how i get on
  16. #13
    Plumbers Arms member Kimou's Avatar
    Jun 2010
    537
    Just thought I'd bump this thread for similar advice.
    A client called me to say they have a problem. I got there and it turns out that the heating is always on. So they have to switch off the boiler and on again when they want H/W or they'll roast in this heat. So I looked further and the spindle for the diverter valve is extended and operating the C/H microswitch. I pushed it down but it resists and pushes up with force. So all's pretty simple and I reckon it's a new C/H PDV diaphragm. Or does anyone suggest something different?
    I'd like to know of other possibilities on my learning curve.
    What I'd like to know in addition to any advice is if a Gas Safe engineer has to do this repair, as I'm a qual'd plumber only. I always thought that if it's not related to flues and gas seals then it's ok to do, but reading things in here, I'm not so sure anymore. Conflicting advice that I've been told.
  1. Potterton Performa Diverter Valve
    By Berger in forum Plumbing Forum
    Last Post: 25-09-2010, 10:53 AM
  2. Check valve faulty?
    By plumbking in forum Valves & Taps
    Last Post: 12-07-2010, 08:44 PM
  3. Faulty 2 port valve
    By I am bonkers in forum Central Heating Forum
    Last Post: 28-01-2010, 09:54 PM
  4. Faulty Torbeck Valve
    By stgiles in forum Plumbing Forum
    Last Post: 18-07-2009, 07:13 PM
  5. p & t valve faulty?
    By sasik in forum Plumbing Forum
    Last Post: 19-01-2009, 10:22 PM
potterton performa 24 drain
performa 24 install -he -eco
