Plumbing & Plumbers Forum - Baxi 105e heating problem
Discuss Baxi 105e heating problem in the Central Heating Forum at Plumbers Forums; Hi. I have a Baxi 105e instant combi Over the past week the heating won't come on, instead the DHW fires up even though the taps are'nt being run , ...
    Post Baxi 105e heating problem
    fires up even though the taps are'nt being run , the DHW and pre-heat work fine
    This happened a few times, I turned the boiler off for a while and it worked OK.
    but now its permanent, also the pump seems to run for a long time.
    Help its cold
    Banned
    Jul 2009
    North Devon
    1,889
    Default Re: Baxi 105e heating problem
    sounds like a jammed/failed diverter valve, time to call in your local rgi to fix it for you.
    Hi funds low, is it hard to replace
    May 2008
    700
    as old plumber said you really need to get a rgi to sort it.
    Banned
    Jul 2009
    North Devon
    1,889
    could be something else as well but unless you can see the boiler and do your diagnostic checks then can be hard to say so best to call in a technician rather then try yourself, however be aware (bad news) 105e instants are getting on and the instants are reknown for failed expn vessels and all the problems this entails, leaks etc so when i come across one nowadays my normal advice is to start saving for a new one as the repairs can cost more in the long term than its worth.
  1. Baxi 105e boiler problem?
    By electricgraham in forum Central Heating Forum
    Last Post: 20-10-2010, 07:00 PM
  2. baxi 105e dhw problem
    By bryan in forum Central Heating Forum
    Last Post: 14-04-2010, 02:28 PM
  3. Baxi 105E Instant problem
    By ajelec10 in forum Plumbing Forum
    Last Post: 03-12-2009, 04:21 PM
  4. baxi 105e pressure problem
    By ronnie in forum Plumbing Forum
    Last Post: 27-12-2008, 01:17 PM
baxi 105e heating problem
baxi 105e heating fault
baxi combi 105e heating problems ukplumbersforums.co.uk baxi 105e heating problembaxi 105e combi boiler heating problemsbaxi 105e instant central heating problemsbaxi 105e central heating problem
