Results 1 to 15 of 20
Plumbing & Plumbers Forum - Britony Combi SE 80 problem.....
Discuss Britony Combi SE 80 problem..... in the Central Heating Forum at Plumbers Forums; Hello people.. Im in need of some serious help.... Have had several plumbers round to look at my heating issue and they just don't come back!!! Basically, my heating doesn't ...-
27-11-2010 #1New to Plumbing Forum
- Nov 2010
- 8
Hello people..
Basically, my heating doesn't work, but i have hot water.... The last guy who came out did a series of tests and we managed to get the radiators hot by bridging or by-passing the "central heating control thermistor" and he also played around with the "central heating water pressure switch" which he seemed to think was working ok as it moved and acted as it should. Im in DESPERATE need to get my hands on a "central heating control thermistor" and ill even have a go at fitting it myself in the hope of actually having some heating this christmas!!! Can anyone help me out with a location of this part, or anything would be good actually! lol.
27-11-2010 #2uɐɯ sɐƃ moderator
- Jan 2010
- maesteg,south wales
- 13,357
- 829
Re: Britony Combi SE 80 problem.....
Gas Appliance Spares (Preston) Ltd - Model ID try here open today give um a ring
GASMAN
27-11-2010 #3New to Plumbing Forum
- Nov 2010
- 8
Kind regards for the link... Was kinda hoping of getting it sorted today but i live near gatwick airport so preston is a little too far to travel! lol. Would there be anyway of setting up a temp switch on it so i could control it manually just for the weekend?
27-11-2010 #4uɐɯ sɐƃ moderator
- Jan 2010
- 13,357
- 829
not really if you order that today you will arrive monday,failing that try a local hrpc
GASMAN
27-11-2010 #5UK Plumbersforums Trusted Advisor.
- Mar 2010
- lincolnshire
- 3,738
- 297
- Thanked 374 Times in 357 Posts
Try here Parts Center
UNIT 2 OAKWOOD ESTATE
GATWICK RD
CRAWLEY
WEST SUSSEX
RH10 9AZ
27-11-2010 #6New to Plumbing Forum
- Nov 2010
- 8
Ordered the part from part center so many thanks for the advice! Will be here on tuesday! Then its just to get it fitted which i may come back on here for techincal advice!
27-11-2010 #7Plumbers Arms member
- Oct 2010
- 1,654
- Thanked 81 Times in 81 Posts
i am wondering now if you could swap the wires over to test that the thermistor is the problem
27-11-2010 #8New to Plumbing Forum
- Nov 2010
- 8
How do you mean? When it was testing about 2 weeks ago from the last guy who came out to have a look, when the connector was taken off the central heating control thermistor, the heating kicked into life. I dont want to disconnect it for it to cause more problems down the line but if there was a way to switch it on and off for periods at a time so i could at least get the house warm, it would be good! For the record, i have absolutely no experience with boilers/central heating at all!!
27-11-2010 #9Plumbers Arms member
- Oct 2010
- 1,654
hi Ian I would not recommend you working on your combination boiler if you have no experience whatsoever as they can be deadly. I am not convinced the part you ordered will sort the problem out as sometimes it is best to change them in pairs, Personally I would get BRITISH GAS or other providers out for a fixed price and it is problem sorted
27-11-2010 #10UK Plumbersforums Trusted Advisor.
- Mar 2010
- lincolnshire
- 3,738
- 297
What area are you in ? somebody on here may be able to come and have a look? Cheaper than BG
27-11-2010 #11Plumbers Arms member
- Oct 2010
- 1,654
BG will be cheaper if there is a more serious issue like a new pump or iffy pcb , oh plus your thermistors for £20 or £40
27-11-2010 #12New to Plumbing Forum
- Nov 2010
- 8
Im located in Crawley, about 10 mins away from gatwick airport. I dont mind having a go, but am well aware that it could go horribly wrong! lol. If anyone on here is local and wants to come and have look, brilliant!! I havent paid for the part but it has been ordered. When you say pairs.... Do you also mean central heating water pressure switch as well? The only reason i know this is cos i helped the guy out that came round last. He showed me that it was still working correctly by the little plunger that moved when you turn the hot tap on. Hopefully it will cure the issue!!
27-11-2010 #13Plumbers Arms member
- Oct 2010
- 1,654
that is for your hot water which is working correctly when you put a demand on for heating is your pump running ?
27-11-2010 #14New to Plumbing Forum
- Nov 2010
- 8
Nothing happens at all when the heating is required. I dont want to mis-read your question by answering it wrong because we tried so many ways to get it working! All i can tell you is what i have said before really... The heating worked when the central control thermistor was disconnected.. Sorry i cant really give you anymore info...
27-11-2010 #15Plumbers Arms member
- Oct 2010
- 1,654
so if that was the case why didnt the guy change it ?
britony combi 80 se
By chamberfive in forum Central Heating ForumReplies: 1Last Post: 16-10-2010, 09:21 PM -
Britony Combi Hot Water Problem
By rking100 in forum Plumbing ForumReplies: 8Last Post: 19-08-2010, 09:10 PM -
Britony Combi 80 SE. Help please.
By Mick Stupp in forum Plumbing ForumReplies: 2Last Post: 13-07-2010, 11:29 PM -
Britony combi se boiler
By BR111 in forum Central Heating ForumReplies: 22Last Post: 29-03-2010, 09:05 PM -
Britony Combi SE 80 - Boiler problem
By tedson in forum Central Heating ForumReplies: 3Last Post: 26-11-2008, 06:31 PM
Low Loss Header Help Needed Please
3 Minutes Ago in Central Heating Forum
