Results 1 to 8 of 8
Plumbing & Plumbers Forum - fernox TF1 leaking
fernox TF1 leaking
Discuss fernox TF1 leaking in the Central Heating Forum at Plumbers Forums; hello i am installing right now a Fernox TF1 filter, no problem for the installation, but i notce a leak coming from the inlet/outlet port where it screws to the ...-
04-11-2010 #1Plumbing Forum Contributor
- Sep 2010
- 52
- Thanked 3 Times in 2 Posts
fernox TF1 leaking
hello
i am installing right now a Fernox TF1 filter, no problem for the installation, but i notce a leak coming from the inlet/outlet port where it screws to the main body.
I never touched it because the return to the boiler runs vertical and the flow direction is as indicated on the filter, it should work without any modification, and without adding or modifying any o-ring.
Has any one of you guys experienced this problem? Must be defective, Do i have to replace the filter?
Please help!!!
Thank youi
02-12-2010 #2New to Plumbing Forum
- Apr 2009
- 4
Re: fernox TF1 leaking
hi
put the horizontal o ring on to get it tight
sometimes they don't sit vertically but at a angle i know it looks crap but it won't leak
02-12-2010 #3UK Plumbersforums Trusted Advisor.
- Jan 2008
- North Yorkshire
- 4,150
There should be a kit of different coloured washers and spacers in the box. Make sure you have the right ones in for the orientation and also that the washer sits properly in the groove.
03-12-2010 #4Plumbing Forum Contributor
- Sep 2010
- 52
Hi
I give it back to the supplier the new one didn't leak at all.
It was originally fitted with the inline valve connection, so didn't need to modify anything.
The fernox technical web site told me to use the next size up (yellow) seal until they will send me a new seal.
Anyway I personally think that the union between filter and boss is a weak point, it can be easily forced when removing the filter cover.
07-09-2011 #5New to Plumbing Forum
- Sep 2011
I had same problem and after contacting Fernox technical department they suggested the factory fitted black o-ring had not been removed before inserting the colored o-ring by the heating plumber.
I took the filter apart and they were right, the yellow o-ring was mangled against the black o-ring. I removed both and fitted the next size up (red o-ring in my case, horizontal flow left to right with black spacer).
I like to say many thanks to Fernox for their advice and supplying me with new o-rings free of charge next day delivery.
07-09-2011 #6Top Plumbing Forum Contributor
- Oct 2008
- Scotland
- 366
- 4
- Thanked 36 Times in 36 Posts
had one leak from bleed point on the top, plastic thread on body had split. merchant replaced it no problems
08-09-2011 #7Steady Plumbing Forum Contributor
- Nov 2010
- North East
- 235
- 14
- Thanked 28 Times in 23 Posts
I had the same bother, black o ring that comes inside as standard is just too pishy, far too easy to nip it and get a leak, to fix it I just put the yellow oring in and gave it an extra nip up. I think they should get a clamping nut and be able to adjust the inlet like you can with the magnabooster.
08-09-2011 #8New to Plumbing Forum
- Sep 2011
- 3
I had faced a similar issue with a fernox, and found a faulty black ring. I replaced both O rings . No issues since I fitted the replacements.
Regards,
ASD
Magna Clean or Fernox TF1
By Dannypipe in forum Plumbing ForumReplies: 35Last Post: 16-04-2011, 09:33 AM -
Magnabooster 2 vs Magnaclean vs Fernox TF1?
By ichilton in forum Central Heating ForumReplies: 38Last Post: 21-03-2011, 11:04 PM -
using fernox DS40
By ggman in forum Central Heating ForumReplies: 3Last Post: 23-11-2010, 03:00 PM -
fernox filter
By buckley plumb in forum Central Heating ForumReplies: 1Last Post: 09-11-2010, 11:12 AM -
Fernox F3 system cleaner
By Davefridge in forum Central Heating ForumReplies: 3Last Post: 06-01-2010, 12:14 AM
My work is drying up???? Help...
3 Minutes Ago in Plumbing Forum
