Plumbing & Plumbers Forum - F and E tank
F and E tank
Discuss F and E tank in the Central Heating Forum at Plumbers Forums; Hi, I've got an F and E tank in loft expanding so much its flowing over the top of tank from time to time, could anyone tell me what level ...-
01-11-2010 #1New to Plumbing Forum
- Oct 2008
- 25
- 8
F and E tank
Hi, I've got an F and E tank in loft expanding so much its flowing over the top of tank from time to time, could anyone tell me what level the ball valve should be set at. I just think its to high. Thanks
01-11-2010 #2Steady Plumbing Forum Contributor
- Jul 2010
- hants
- 232
- 7
- Thanked 26 Times in 25 Posts
Re: F and E tank
hi approx 4 gals in the tank , that's why they are 10/4 tanks 10 gallon actual capacity designed for 4 gallons nominal
46
The Following User Says Thank You to ferret For This Useful Post:
rmbp (27-11-2010)
02-11-2010 #3UK Plumbersforums Trusted Advisor.
- Jan 2008
- North Yorkshire
- 4,155
Re: F and E tank
Set the ball cock so that the level is about 1/2 the way from the bottom of the tank to the overflow.
If the problem has been going on for some time you may need to add more corrosion inhibitor.
The Following User Says Thank You to WHPES For This Useful Post:
rmbp (27-11-2010)
Solar panels and tank. Install tank first then panels ?
By edwardk in forum Renewable EnergyReplies: 7Last Post: 21-10-2010, 11:55 AM -
Rat in the tank
By Dannypipe in forum Plumbing ForumReplies: 24Last Post: 23-06-2010, 10:24 PM -
oil tank
By buffy27 in forum Plumbing ForumReplies: 5Last Post: 25-04-2009, 10:00 PM -
C/H header tank feed pipe pushing hot water into tank
By RON in forum Central Heating ForumReplies: 11Last Post: 16-06-2008, 09:57 PM -
By RON in forum Central Heating ForumReplies: 0Last Post: 05-06-2008, 11:19 PM
Link Exchange - Plumbing Site
6 Minutes Ago in Links, Forum Updates, News and Site Suggestions
