Results 1 to 15 of 16
Plumbing & Plumbers Forum - can i run in 10mm then up it to 15mm??
Discuss can i run in 10mm then up it to 15mm?? in the Central Heating Forum at Plumbers Forums; Hi guys, my mum and dad had an extension built about 15 years ago. one thing they have always complained of is that they do not have a radiator in ...
    Aug 2010
    173
    Default can i run in 10mm then up it to 15mm??
    Hi guys,
    my mum and dad had an extension built about 15 years ago. one thing they have always complained of is that they do not have a radiator in the extension. They have 2 radiators in the living room but these struggle to heat the extension as well.
    anyway, i was thinking of putting a radiator in there for them. problem is the floor in the extension is concrete, whereas the rest of the ground floor is floorboards that i can take up to get to the existing 15mm pipe work.
    i dont want to run any pipe in conduit and would rather hide the pipes as best i can.
    i was thinking i could 'T' into the existing 15mm pipe work, channel out the concrete floor so that i can run 10mm to were i want the radiator and then put a 15 to 10 mm reducer on the end to up it to 15mm so i can connect to rad (want 15mm at rad a others are 15 and feel it would look better)
    does anyone see a problemin doing this?? advice much apreciated
    Robtheplumb
    Default Re: can i run in 10mm then up it to 15mm??
    If you are going to channel the concrete floor for 10mm why don't you channel it a little bit deeper and wider and put 15mm in? You will save yourself a load of agro with reduceing sets and all other problems.
    tamz's Avatar
    Scotland
    9,397
    No problem. Use coated 10mm if you are burying it in the screed.
    Aug 2010
    173
    thanx guys, how deep would i have to bury the pipes if using either 10 or 15mm and what the stuff to use to cover them back up?? i.e motar, self leveling compound etc
    tamz's Avatar
    Scotland
    9,397
    Quote Originally Posted by beesley121 View Post
    Depends how long it takes for your arms to get sore swinging a 4lb mash
    Around 1" below the ffl and just fill it in with mortar.
    kirkgas's Avatar
    Dec 2009
    Coatbridge, Lanarkshire
    3,515
    Quote Originally Posted by tamz View Post
    gas pipes require to be covered with 25mm screed above the pipe, not actually sure what the reg is for water, but it wont be far away, you could get away with 10mm depending on a couple of things, the existing length of the 15mm run, the size of the rad it feeds and the size of the new rad, scroll through for posts on max kw a 15mm supply will feed (6kw rings a bell, but someone will gently and politely remind me if im wrong!!) 15mm will be better, but needs to be covered, as others have said 10mm insulated is available off the shelf
    Oct 2010
    1,654
    why not use hep hence only one joint
    Aug 2010
    173
    Quote Originally Posted by gasmarc View Post
    thanx for the idea mate but to tell u the truth, im no fond of hep unless is a tricky install. heres my reasons
    costs as much as copper, if not more. copper will last years. im still not convinced you will get +20 years with hep due to the rubber seals perishing. ive got a felling that there will be a lot of work finding/fixing leaks in 10-15 years time when all these rubber seals begin to persih. also i like nice vertical pipes to the rad, not pipes that kinda slope upwards to the rad if yer know what i mean.
    not having a go mate or anything. i appreciate your reply but ive just got a bit of thing about hep lol
    Oct 2010
    1,654
    no i agree with what you say except for having more joints on copper ,so you think there will be loads of work in the future when the hep fails Great lol
    Banned
    Jul 2009
    North Devon
    1,889
    not being funny but whats wrong with tidy 15mm running along a skirting to a rad, saves a lot of mess and possibility of cutting through your damp course and starting loads of future problems. Easy option is often the best in these situations
    Gray0689's Avatar
    Jun 2010
    Northern Ireland
    4,671
    Default
    Quote Originally Posted by oldplumber View Post
    It looks crap I hate surface run pipework
    Banned
    Jul 2009
    North Devon
    1,889
    it only looks crap when its badly installed, after all a leaking system in a concrete floor looks pretty awful as well. Anyhow most folks throw a sofa in front and you cant see it anyhow.
  13. #13
    Gray0689's Avatar
    Jun 2010
    Northern Ireland
    4,671
    Default
    Ifits done right it won't leak in concrete floor will it and look better
  14. #14
    Aug 2010
    173
    always think that running pipes along skirting to rads looks dam rite awful. i would kick someone out of my house if thy did that. looks to me 'unprofessional'. but thats just my opinion
  15. #15
    east london
    6,666
    use 10 mm pipe brought up behind the skirting use 10mm rad valves with street elbows and you wont see any pipe work
  1. What is the best 10mm mini bender
    By rocky in forum Plumbing Tools
    Last Post: 09-02-2011, 10:35 AM
  2. 22mm to 10mm CH Manifolds
    By kga1956 in forum Central Heating Forum
    Last Post: 08-06-2010, 10:55 PM
  3. Trv 8/10mm inserts
    By XDog360 in forum Central Heating Forum
    Last Post: 05-12-2009, 09:29 PM
  4. Connecting 15mm copper to chrome 15mm
    By madmart in forum Fittings & Pipes
    Last Post: 04-08-2009, 12:23 AM
  5. 15mm pipe on 10mm system
    By woodi2 in forum Central Heating Forum
    Last Post: 13-11-2008, 09:55 PM
10mm or 15mm central heating
central heating 10mm or 15mm
10mm 15mm central heatingwhich is best10mm or 15mm central heatingwho do you connect 10mm pipe to 15mm radiatorcan yuo connect 10mmcentral heating 10mm pipe can it be increased to 15mm
