Results 1 to 12 of 17
Plumbing & Plumbers Forum - Salus RT500RF Thermostat not controlling boiler?
Like Tree4Likes
Discuss Salus RT500RF Thermostat not controlling boiler? at UK Plumbers Forums; Hi. I have just had a Gloworm 30 CXI Ultracom 2 installed with a Salus RT500RF Wireless Programmable Thermostat to control temperature. All my radiators have TRVs and I have ...
    Sep 2010
    Default Salus RT500RF Thermostat not controlling boiler?
    Hi. I have just had a Gloworm 30 CXI Ultracom 2 installed with a Salus RT500RF Wireless Programmable Thermostat to control temperature. All my radiators have TRVs and I have noticed that the Salus is not switching the boiler off or stopping flow to the rads when it should be. Eg at 10pm I am asking to it maintain a room temp of 10c, the Salus thermometer is reading the room temp circa 22c after the heating has been on, but the boiler is still in central heating mode and the rads hot all night.
    I have tested the device to make sure the transmitter is working with the receiver and the green light on the receiver does come on when a request to raise the temperature is sent, but I have never seen the green light on when I have either manually asked to drop the temp or when the program changes to say a "maintain 10c cycle" eg overnight.
    I have seen on the internet that these things are notoriously unreliable. Does anyone have any advice? Installer showed me it working so had no reason to doubt it worked? I would expect the central heating mode on the boiler to switch off when the room temp was being maintained well above the set level. Does this point to a communication problem with the Salus? Thanks in advance.
    Banned
    Aug 2009
    1,509
    Default Re: Salus RT500RF Thermostat not controlling boiler?
    Is there a TRV on the rad in the room where the Salus is located? If so, you should either set the TRV to maximum or remove the head from the TRV - no water will come out.
    Have you used all five time/temperature settings on the Salus? You must set no five to be the overnight one, even if it means setting two the same.
    Does the boiler go out if you turn the temperature down to minimum and relight if you turn it up to max?
    uɐɯ sɐƃ moderator
    gas man's Avatar
    18,661
    salus products are unreliable,used there rf stats nothing but problems only fit honeywell now
    gassafe and Darren Jackson like this.
    Sep 2010
    Thanks for the responses. I have set all 5 cycles on the thermostat. TRV are on max setting in the living room where I keep the thermostat. At 10pm the thermostat will hit the 5th cycle and should tell the boiler to maintain a room temp of 5c. I am currently in the living room with the rads very hot to the touch and a reading of 22.5c so I would expect the boiler to switch off the CH mode and the heat to leave my rads. I am actually going to go and watch the boiler at 10pm to see what/ if anything happens. If my rads are still boiling hot at 11 then I know the Salus thermostat is bloody useless!!!
    Is there any chance that the TRV are actually controlling the boiler ie by keeping them on max they are continually trying to regulate the room temp? ( I think max is 25c+) I would have thought the Salus should be the one dictating what the boiler should do though otherwise is it impossible to have timed CH. Cheers.
    @Doitmyself - Do you mean turn the temp down on the stat or the actual boiler interface?
    uɐɯ sɐƃ moderator
    gas man's Avatar
    18,661
    i just think the salus is knackered get a more reliable stat
    Sep 2010
    @ gasman - I think you may be onto something lol
    55 mins on and my rads are blistering hot with no drop in temperature!
    I have reset the thermostat several times and tried to manuallyreduce the temperature on it using the overide, but no reaction from the boiler or the Salus wired receiver whatsoever.
    Just seems odd that it will allow me to raise the temperature (green led comes on) but never decrease it (no green led, "click" or reaction from the boiler). As is stands I have no way to control the heating via the thermostat so cannot have timed CH. I have had to switch the CH mode off on the boiler. I'll be getting in touch with my installer!
    tamz's Avatar
    Scotland
    13,955
    In the meantime remove the batteries and reset it.
    Then get a honeywell fitted.
    Salus should be spelt shi..
    gas man likes this.
    Banned
    Aug 2009
    1,509
    Quote Originally Posted by Grovis View Post
    The TRV is a thermo-mechanical device and is completely independent of the the boiler. All it does is control the flow through the radiator to maintain the required room temperature.
    I was meaning the wall thermostat.
    PS I agree about replacing it with a Honeywell.
    Sep 2010
    Had the installer out and it was actually a setting inside the boiler which should have been switched off before they wired the Salus receiver. There was continous heating or something along those lines, so the boiler was overiding any requests from the stat to turn down. Anyway 2 days in and the Salus has been good as gold and totally responsive. I will see how it goes but have your recommendations for a Honeywell ready if anything does go pear shaped. Thanks for you help.
    Jan 2015
    Hi I have the same problem as Grovis. I have the salus rt500rf and a potteron gold he. Does anyone know where the switch is inside the boiler to turn off the override that keeps it heating as abovr.
    Moved in to new property and its like a sauna in here at night!
    Thanks.
    Banned
    Sep 2010
    3,259
    1. you need to start a new thread
    2. you must be gas safe registered to open a boiler
  12. The Following User Says Thank You to jase158 For This Useful Post:
  13. #12
    uɐɯ sɐƃ moderator
    gas man's Avatar
    18,661
    Quote Originally Posted by Hornberrie View Post
    Thanks.
    there is no switch inside the boiler,as jase said,you need a gas safe engineer
  14. The Following User Says Thank You to gas man For This Useful Post:
  1. salus RT500RF wiring
    By rob652nan in forum Central Heating Forum
    Last Post: 09-02-2013, 08:52 AM
  2. Salus rt500rf & glowworm 30? Help!
    By Hock in forum Central Heating Forum
    Last Post: 06-01-2013, 12:03 AM
  3. Salus RT500RF 868Mhz Unit Working When Switched OFF
    By andymanila in forum Central Heating Forum
    Last Post: 27-07-2012, 11:23 PM
  4. Salus RT500RF remote programmable room stat
    By simbo116 in forum Central Heating Forum
    Last Post: 02-03-2012, 05:07 AM
  5. Salus RT500RF Woes
    By Chromedome in forum Central Heating Forum
    Last Post: 24-01-2012, 03:14 PM
  6. Controlling ATAG, UFH, and radiators
    By evb222 in forum Central Heating Forum
    Last Post: 18-08-2011, 12:23 AM
  7. Replies: 5
    Last Post: 09-11-2010, 12:20 AM
  8. Adding a Salus RT500RF Room Thermostat to Ariston EuroCombi
    By BigManCheese in forum Central Heating Forum
    Last Post: 11-02-2010, 10:42 PM
  9. Combi boiler issue controlling non-thermo shower
    By Jimmy Gear in forum Plumbing Forum
    Last Post: 15-01-2010, 10:41 AM
salus rt500rf problem
salus thermostat problems
salus rt500rf troubleshooting
rt500rf problems
salus wireless thermostat problems
