Results 1 to 6 of 6
Plumbing & Plumbers Forum - Glowworm Micron boiler
Discuss Glowworm Micron boiler in the Central Heating Forum at Plumbers Forums; Hi, 1st post on this forum and it's a help post! Here's the situation I have a glowworm micron 70ff boiler and a couple of weeks ago it packed up. ...
    dirtydog
    Default Glowworm Micron boiler
    Here's the situation I have a glowworm micron 70ff boiler and a couple of weeks ago it packed up. This is what happened...
    There was a pop from the kitchen (where the boiler is) and the consumer board tripped out, I reset it and couldn't find why it tripped. Next there was no hot water so thought the boiler would need resetting again as it kept over heating. There was no power getting to it so changed the fuse in the switched spur and still nothing! Checked the internal fuse on the boiler and that was fine too. My intial thought is that the PCB is knackered, what's peoples thoughts? I haven't had much to do with boilers yet as most of my work at the moment is fitting bathrooms.
    Oct 2008
    671
    Default Re: Glowworm Micron boiler
    is their power to the rest of the controls or is it just the boiler with no power.
    how can it keep overheating if theses no power.
    one of the first things to check is the pump.
    dirtydog
    Just seems to be the boiler with no power, although i haven't checked the pump for power, the programmer is working so would seem to have power up to the main junction box
    The overheating issue was happening before it died
    When it kept overheating we had just the HW on and the DH off
    Mike Jackson's Avatar
    Hastings
    3,888
    There were issues with the PCBs going on Microns but I'd suggest that you get someone in to have a look at it before splashing out.
    Mike
    dirtydog
    Quote Originally Posted by Mike Jackson View Post
    Mike
    Thanks for the advice Mike but i'm training as a plumber and should be doing my Corgi registration soon so would like to sort this myself and am just trying to get an idea if i'm right about it being the PCB
    dirtydog
    Right a bit more info now, this evening i've checked the fan in the boiler to make sure it isn't jammed and it's spinning freely i've also had the head off the pump and that is turning nicely as well.
  1. disconect solid fuel back boiler
    By spencer in forum Plumbing Forum
    Last Post: 06-11-2009, 05:09 PM
  2. problem with commercial boiler.
    By griffdsp in forum Plumbing Forum
    Last Post: 13-08-2009, 07:20 PM
  3. Advice require - Electric Water Heater / Old Gas Boiler
    By salbal77 in forum Plumbing Forum
    Last Post: 16-04-2009, 08:16 AM
  4. Replies: 11
    Last Post: 10-02-2009, 06:28 PM
  5. Boiler gas feed pipe pressure...
    By JMA in forum Plumbing Forum
    Last Post: 02-11-2008, 11:02 PM
glow worm micron no hot water
micron boiler
glow worm 70ff keeps resetting
micron boiler problems
how to reset glow worm boiler
glowworm micron how to reset and program
glowworm micron no power
