Old 02-11-2008   #1 (permalink)
oakworth96
View oakworth96's Photo Album
Red face vokera 20/80 flowmatic no hot water
Good morning,
When i turn on the hot water tap the spindle does not move to switch on the microswitch,i removed the 3 way diverting valve and checked the workings and the spindle pushes out fine.i adjusted the water flow to see if the spindle pushes out but to no joy,i wondered if the problem could be domestic hot water manifold which is behind the 3 way diverter or it could be a thermostat problem.I could replace these parts but if that does not sort the problem then ive wasted £130 on these parts
thanks
oakworth96 is offline   Reply With Quote
Old 02-11-2008   #2 (permalink)
Mike Jackson
View Mike Jackson's Photo Album
Default Re: vokera 20/80 flowmatic no hot water
If unsure get a professional in to look at it for you. It's a lot safer and sounds as though it would be cheaper in the long run than just throwing parts at it until you have fixed the problem.
Just in case you do actually know what you are doing it sounds like it could be a split diaphragm but I'm not very familiar with Vokera boilers.
Mike
Mike Jackson is offline   Reply With Quote
Old 05-11-2008   #3 (permalink)
gascob
View gascob's Photo Album
i agree with mike you're looking at a torn/perished diaphragm there, if you are gonna do it yourself just buy the diaphragm, you don't need the full housing(and its only a few quid for a diaphragm), but as mike quite rightly says only attempt this if you are confident and competent!!
gascob is offline   Reply With Quote
Old 06-11-2008   #4 (permalink)
oakworth96
hi,i checked the diaphragm and its ok,also checked its workings so and it seem fine, the pin pushed out when i turned the hot tap on, so ive ordered the 3 way diverter for £49+vat.i,ve managed to get it workin by turning up the flow rate then opening the hot tap till its limit for a few seconds the turning it back down,this pushes the pin out and also gives me hot water,thanks for your help and i'll let you the outcome
Shower hot water problem deaddraw Plumbing Forum 5 10-11-2008 10:53 PM
hot water peterrawlings Central Heating Forum 1 08-11-2008 12:10 AM
hot water keeps cutting out on combi system obseen16 Plumbing Forum 2 21-08-2008 11:24 AM
Boosting gravity fed hot water feed to kitchen J-Tuner Plumbing Forum 3 19-08-2008 05:27 PM
