Old 31-10-2008   #1 (permalink)
Jamie757
View Jamie757's Photo Album
Default Central Heating System Failed!
Hi all,
First post so bear with me! Earlier today, my central heating/hot water system failed. The system comprises an Ideal Elan 2 boiler, a Honeywell thermostat, two header tanks in the loft and a cylinder in the airing cupboard.
For about a month now, the CH has only been working with the HW switched on and when it is on, the boiler seems to operate for about 30 seconds before switching off again in a repetitive cycle.
Anyway, a little earlier, the boiler stopped operating and I can't get it to light.
If anybody could shed a little light on my problem it would be greatly appreciated!
Best regards, Jamie.
Jamie757 is offline   Reply With Quote
Old 31-10-2008   #2 (permalink)
sonray ltd
View sonray ltd's Photo Album
Default Re: Central Heating System Failed!
has the boiler tripped and needs resetting
Old 31-10-2008   #3 (permalink)
Jamie757
Thanks for your reply, I've shut the boiler down and relit the pilot a couple of times, it just doesn't seem to want to light! The timer (ACL LP241) is calling for heat as far as I can see!
Old 31-10-2008   #4 (permalink)
sonray ltd
can you hear the fan etc coming on the boiler before it trys to light ?
Old 31-10-2008   #5 (permalink)
Jamie757
No, it doesn't seem to be making any noises or doing anything, apart from a click after shutting it down.
Rgds.
Old 31-10-2008   #6 (permalink)
sonray ltd
has the programmer still got a display up ?
when calling for heat etc is the pump running ?
Old 31-10-2008   #7 (permalink)
Jamie757
Ok, so the boiler has just sprung back into life after being switched off for about an hour and restarted, the programmer seems as normal, display, indicators illuminated etc.. I can hear a whirring noise coming from the airing cupboard, can't quite tell if it's coming from the silver box (a valve of some sort I assume ) or the pump though.
Think I'll be phoning for an engineer to come and inspect it!
Many thanks for your replies so far, much appreciated! Any info on the other faults, CH only working with HW would be great, then I can get a feel on what may be wrong, possible costs and whatnot!
Old 31-10-2008   #8 (permalink)
sonray ltd
your first fault is with the valve it sounds like its a faulty microswitch.
Old 31-10-2008   #9 (permalink)
Jamie757
Many thanks for your help Sonray! Much appreciated!
Regards, Jamie.
Old 05-11-2008   #10 (permalink)
gascob
View gascob's Photo Album
Jamie, i'd guess you just need a new synchron motor in the valve in your airing cupboard( the silver thing) this is what is stopping your heating coming on alone budget about 18-20 quid for the part... easy to do once power is positivly isolated!! but don't get ripped off by someone saying they will need to change the full valve and drain the system down etc... 20 minute job to just change the motor!!
The elan doesn't have a fan so you won't hear one... if the pilot stays lit but goes out after a minute or so its overheating so i would suspect the pump or a blockage...
hope this helps...
gascob is offline   Reply With Quote
Installing a thermastat into a central heating system the chef Central Heating Forum 2 31-10-2008 09:57 PM
Central Heating Quote makmak Central Heating Forum 5 27-10-2008 10:26 AM
refilling a central heating system cherryb Central Heating Forum 8 18-10-2008 09:29 PM
How to loose a rusty drain cock in central heating system michael2008 Plumbing Forum 1 13-10-2008 10:07 AM
Another way to drain central heating while drain cock is rusty and unscrewable michael2008 Central Heating Forum 1 12-10-2008 11:00 PM
