Old 23-10-2008   #1 (permalink)
hughs
View hughs's Photo Album
Default Gas Inlet Working Pressure in Vaillant 630 system boiler
The gas inlet working pressure in the Vaillant EcoTec plus 630 System Boiler is 16.5 mbar. The recommended pressure for this boiler is in the range 17 – 25 mbar.
The gas flow rate is 3.2 cubic metres per hr for natural gas. The recommended rate in cubic metres per hr is:
Nominal – 3.24
+5% - 3.40
-10% - 2.91
I am told that the output pressure from the gas meter is set at its maximum.
If the working pressure is very slightly less than the recommended rate, what are the implications? If I need to increase the gas pressure, what do I need to do?
Is the gas flow rate ok, noting the above readings?
Anything else that I should consider?
Many thanks for your help.
hughs is offline   Reply With Quote
Old 25-10-2008   #2 (permalink)
grahamep
View grahamep's Photo Album
Default Re: Gas Inlet Working Pressure in Vaillant 630 system boiler
Who installed this boiler and when?
Ignore that previous reply. I have looked at your other posts and it seems that this is a DIY job. You have two problems. The first is that you have a legal requirement to inform your local building control of the new installation. If this doesn't cost you now then it will when you come to sell the house. Secondly your gas supply pressure. If it is within the specs of the boiler then it is not going to adversely affect performance. If the pressure does drop due to demand, then with Vaillants you will get a rapidly oscillating whoomph from the burner. From the other questions you have asked I don't think any responsible competent person should tell you how to sort your low pressure other than for you to call a CORGI engineer.
grahamep is offline   Reply With Quote
Old 25-10-2008   #3 (permalink)
yammas
View yammas's Photo Album
Exclamation Re: Gas Inlet Working Pressure in Vaillant 630 system boiler
Yes, RGI should not give out advice on how to check appliances to anybody,
and the only advice should be contact a CORGI installer, all gas applainces installed have to be notified to LBC, my advice to any body posting threads regarding any gas appilance would be
"If in doubt get a CORGI to CHECK IT OUT"...its for your own safety!!
yammas is offline   Reply With Quote
Separate pump in addition to the one included in the condensing boiler? hughs Central Heating Forum 7 18-11-2008 06:05 PM
Which Boiler – Vaillant, Glow-Worm, Worcester? Fit Magnaclean? hughs Central Heating Forum 5 18-11-2008 06:03 PM
Boiler gas feed pipe pressure... JMA Plumbing Forum 11 03-11-2008 12:02 AM
Advice require - Electric Water Heater / Old Gas Boiler salbal77 Plumbing Forum 0 12-10-2008 07:18 PM
YPlan wiring help needed flying lee Central Heating Forum 2 13-09-2008 01:31 PM
