Results 1 to 10 of 10
Plumbing & Plumbers Forum - baxi 105e zero pressure
Discuss baxi 105e zero pressure in the Central Heating Forum at Plumbers Forums; had a quick search for baxi problems and got pages and pages of responses so guessing this isnt the greatest boiler around !! had the boiler for about 10 years ...
    Sep 2010
    19
    Default baxi 105e zero pressure
    had the boiler for about 10 years and in that time had a few issues including having to have pcb replaced a few years back, it was given an annual service about 4 weeks ago and only problem was that the discharge pipe outside had been continually dripping and that was sorted.
    yesterday put the shower on and got no hot water, checked teh boiler and pressure was on zero, in the past if its been low i just turn the tap underneath and problem solved but this time that had no effect, then the fault light for no pressure of problem with fan started to flash. if you turn the hot water on slowly and give it time then it seems to be ok and works but pressure still remains at zero and never increases. today again we had the same issue and its just very hit and miss with hot water. tried the central ehating to see if that works and boiler comes on and goes through the full cycle but radiators just dont seem to heat up and boiler is making a high pitch npise which ive never been aware of before !
    any ideas on why pressure is zero and how i go about increasing it or what teh probelm may actually be ? thanks a lot
    uɐɯ sɐƃ moderator
    gas man's Avatar
    maesteg,south wales
    13,339
    Default Re: baxi 105e zero pressure
    its low on water you sound like you have a faulty filling loop,it is one of the best combis you can buy
  3. GASMAN
    IMPOR
    Sep 2010
    North Notts
    15
    If you had it looked at 4 weeks ago get them back and as gas man says it is one of the best around.
    Sep 2010
    19
    called teh guy who serviced it and he's away on holiday for the next 3 weeks ! dont want to wait that long if i can help it.
    is there any way i can check if it is just a fualty filling loop ? if disconnected the loop just to make sure its not something simple like a blockage but it seesm fine
    Sep 2010
    19
    problem sorted ! just had a look again and where the filling loop was connected to the cold water inlet pipe there was a valve just above the loop and that had been closed off so when i was turning tap on loop it obviously wouldnt do anything ! as soon as i openeed the valve the pressure shot straight up.
    guess the guy that came out closed it for some reason and forgot to reopen it !!
    Aug 2010
    belfast
    166
    he done the right thing by closing it off. the fill loop should be turned off disconnected and capped
    Sep 2010
    19
    why's that ? had the boiler for about ten years and had it serviced every year and thats never been done before.
    Aug 2010
    belfast
    166
    because if the fill loop passes it will over pressurise your system and if the nonreturn valve fails your heating water could contaminate the mains water in your area
    Sep 2010
    19
    thanks for that diesel, ive shut the valve back off again and kind of makes me wonder why thats never been done before when teh boiler has always been serviced every 12 months
    Aug 2010
    belfast
    166
    i come across this all the time and to be honest its just laziness but if you as a heating engineer were found to contaminate the mains i'm sure there would be big fines for not complying with water bylaws
  1. baxi 105e rising pressure
    By seanmfc in forum Plumbing Forum
    Last Post: 29-09-2010, 08:45 PM
  2. baxi 105e
    By calrob in forum Central Heating Forum
    Last Post: 26-12-2009, 11:02 AM
  3. Baxi 105e
    By boilerbaby in forum Central Heating Forum
    Last Post: 29-03-2009, 06:26 PM
  4. baxi 105e pressure problem
    By ronnie in forum Plumbing Forum
    Last Post: 27-12-2008, 01:17 PM
  5. baxi 105E combi pressure rise.
    By gazza247 in forum Central Heating Forum
    Last Post: 24-12-2008, 01:53 AM
baxi 105e filling loop
baxi 105e low pressure problems
baxi combi 105e pressure
baxi combi 105e filling loop
baxi combi boiler 105e filling loop
baxi 105e filler tap not working
is there a way to pleasure a baxi 105 boiler without a loop
