Results 1 to 8 of 8
Plumbing & Plumbers Forum - Poor hw flow from a combi.
Discuss Poor hw flow from a combi. in the Central Heating Forum at Plumbers Forums; I have a sime super 90 combi boiler. Hot flow has suddenly decreased, yet cold is fine. Whats the usual culprit?...
    Steady Plumbing Forum Contributor traineedrip's Avatar
    Jan 2009
    225
    Default Poor hw flow from a combi.
    Jun 2010
    698
    Default Re: Poor hw flow from a combi.
    Might be a filter on cold inlet to valve. Before you strip it down to look there's a flow adjuster on the outlet of the diaphragm housing, try adjusting, using a 7 or 8 mm spanner. might justbe some crud stuck in it .
    Sep 2010
    North Notts
    15
    Blocked filter usually
    Sep 2010
    100
    been to a few where hw heat exchanger has scaled up especially if no limefighter fitted on the cold supply., Take it out and use Spirit of salts solution which i think is hydroclauric acid. Just fill it up and let it soak for 5mins then wash the crap out and refit. only 20 min job!
    Jan 2009
    225
    Thanks all. Problem solved mysteriously by itself a couple of hours later. Looking back i think cold pressure had reduced too but far less than hot, so im putting it down to something external on the main. Boiler is 13 years old so id imagine the filter is choking the hot to some extent.
    fuzzy
    good result then!! keep a clsoe eye on it you have some ideas for future mate
    Sep 2010
    57
    Quote Originally Posted by PlumbingSucks View Post
    You can soak it in vinegar aswell mate (tip I got from an old codger I worked with)
    Sep 2010
    100
    Nice tip thanks. Didn't know kim and aggy were plumbers aswell just thought they cleaned houses. LOL
  1. good pressure but poor mains flow?
    Last Post: 14-08-2010, 10:07 PM
  2. poor flow from open vented cylinder
    By sparky in forum Plumbing Forum
    Last Post: 01-05-2010, 08:36 AM
  3. Baxi Combi Boiler, CH fine, Water heating poor
    By naskinner in forum Central Heating Forum
    Last Post: 21-01-2010, 09:21 PM
  4. Poor Hot Flow To Sink Mixer In Bungalow
    By woodbine in forum Plumbing Forum
    Last Post: 01-08-2009, 06:22 PM
  5. Poor flow from shower head!!
    By dsinclair999 in forum Bathrooms, Showers and Wetrooms
    Last Post: 05-10-2008, 11:42 PM
