Pump problems
I ieed help pls .
The system is :an electric boiler ,pump for flow,3 port valve, open dhw cylinder and a second pump which is connected to the dhw pipe, out to the consumer .The problem I have is that the second pump, (dhw /shower/tap) is running more or less all the time even though no one is using the hot water(no drips)and is very noisy !
I wonder, if I install a one- way valve (check valve ) at the outlet of the pump, will it keep the pressure on the pipe,so that the pump is only running when the tap/shower is in use.
I wonder if any of you have any ideas?
