Results 1 to 15 of 21
Plumbing & Plumbers Forum - Ideal classic RS50 with Honeywell control
Discuss Ideal classic RS50 with Honeywell control in the Central Heating Forum at Plumbers Forums; Boiler works OK, but regardless of 'ON' or 'OFF'position of heating slider, radiators come on at same time as hot water. This control has one clock with option of two ...-
21-09-2010 #1New to Plumbing Forum
- Sep 2010
- 10
- 3
- Thanked 1 Time in 1 Post
Boiler works OK, but regardless of 'ON' or 'OFF'position of heating slider, radiators come on at same time as hot water. This control has one clock with option of two on-off per 24 hours: separate slide for heating and hot water. Didn't do this last year. Just that I don't want heating on every time I need hot water.
21-09-2010 #2Super Plumbing Forum Contributor
- Aug 2009
- 1,107
- Thanked 108 Times in 104 Posts
Re: Ideal classic RS50 with Honeywell control
Possibly a motorized valve fault.
You should have one or two motorized valves - usually near the hot water cylinder. How many and what type - Flow (straight through pipe) or Mid-position (pipes in a T)?
21-09-2010 #3New to Plumbing Forum
- Sep 2010
- 10
- 3
I have seen these in other systems, but (believe me) there are non either near the Hot Water cylinder nor at the boiler. And I don't recall seeing any under the floor either !
21-09-2010 #4Super Plumbing Forum Contributor
- Aug 2009
- 1,107
How many pipes connected to the boiler - ignore the gas pipe?
The Following User Says Thank You to doitmyself For This Useful Post:
George Owenson (21-09-2010)
21-09-2010 #5New to Plumbing Forum
- Sep 2010
- 10
- 3
Hi doitmyself - thanks for your help on this. Two water pipes lead in to th topof teh boiler. One cold in and one hot out. The hot put has several connections off gojng elewhere, with one back to teh cylinder. The boiler has two additional blanked-off pipes, one each at inlet and outlet. Hope you understand this explantion
21-09-2010 #6Super Plumbing Forum Contributor
- Aug 2009
- 1,107
I think I've got that.
That means the system must be fully pumped.The boiler has two additional blanked-off pipes, one each at inlet and outlet. Hope you understand this explanation
Do you have a thermostat on the side of the HW cylinder -about a foot up, usually help in place by a strap round the cylinder?
21-09-2010 #7New to Plumbing Forum
- Sep 2010
- 10
- 3
The Cylinder is like an octopus with pipes all over. Hot in and out, also cold in at the bottom, and another disappears round the back.
But no strap and no thermostat !
21-09-2010 #8Super Plumbing Forum Contributor
- Aug 2009
- 1,107
Can you post a photo of the Hot water cylinder and all the surrounding pipework etc?
21-09-2010 #9New to Plumbing Forum
- Sep 2010
- 10
- 3
Will do, but Wednesday - got appointment tonight. Thanks, hope you'll come back tomorrow!
21-09-2010 #10Super Plumbing Forum Contributor
- Aug 2009
- 1,107
21-09-2010 #11Steady Plumbing Forum Contributor
- Jul 2010
- hants
- 232
- 7
- Thanked 26 Times in 25 Posts
George you haven,t said whether its always been like this or not , we can understand better with a full sp ,its very unusual not to have any MV,s
46
22-09-2010 #12New to Plumbing Forum
- Sep 2010
- 10
- 3
Thanks to all helpers. Photo of cylinder. Hot from boiler bottom left (cock/tap). Large cold pipe continues to upper floor behind cylinder. No more connections out of frame. Coiled mains cable is for immersion heater. Green sludge is very old. This is a new problem.
22-09-2010 #13Super Plumbing Forum Contributor
- Aug 2009
- 1,107
Definitely no sight of a cylinder thermostat or motorized valve.
So how was the hot water temperature controlled?
You say that last year you could have the HW on without the heating. Are you talking about in the summer or the winter?
Do you have a room thermostat?
Make and model of the timer/programmer?
Where is the pump located?
Photo of boiler and surrounding pipework, please.
22-09-2010 #14New to Plumbing Forum
- Sep 2010
- 10
- 3
At Boiler
Any time
No, thermostatic valves throughout
At Boiler again I think
22-09-2010 #15Super Plumbing Forum Contributor
- Aug 2009
- 1,107
Has any work been done to the system recently? If so what and by whom?
Ideal classic mystery
By Jackbooted in forum Plumbing ForumReplies: 3Last Post: 25-03-2013, 06:44 PM -
Ideal Classic low water pressure
By GASMAN10 in forum Central Heating ForumReplies: 3Last Post: 14-06-2010, 08:26 PM -
ideal classic nf 50
By radford in forum Plumbing ForumReplies: 0Last Post: 08-02-2010, 09:01 PM -
Ideal Classic wont fire
By Alanc in forum Central Heating ForumReplies: 0Last Post: 01-02-2010, 08:40 PM -
british gas rd1 360 (ideal classic)
By lurkeyo2000 in forum Central Heating ForumReplies: 9Last Post: 29-01-2010, 11:37 PM
Hi all
2 Minutes Ago in New Member Introductions
