Old 20-10-2008   #1 (permalink)
Londonluke
View Londonluke's Photo Album
Default Wireless room stat positioning?
Imagine a 4 story luxury house . Some issues with heating. Visited today and noted that wireless thermostat is on top floor and the boiler receiver is in the basement !! God only knows if the signal can travel that far !
Now.... on the top floor is master bedroom and bathroom
but i feel it the wrong place for the thermostat as its too high up the house
i need suggestions !
cheers
Londonluke is offline   Reply With Quote
Old 20-10-2008   #2 (permalink)
sonray ltd
View sonray ltd's Photo Album
Default Re: Wireless room stat positioning?
if its wireless remove it and try it somewhere more suitable.
Old 20-10-2008   #3 (permalink)
mcmoby69
View mcmoby69's Photo Album
read installation instructions. standard position for a stat/programmer is in the hall. receiver unit may be able to be extended from the boiler closer to sender unit. check with manufacturer to see how far it can be extended. because it is low voltage there may be issues with volt drop over a long distance.
Old 20-10-2008   #4 (permalink)
Londonluke
Quote:
its in the stairwell 4 floors up of a big house! i wonder if its a good loc ation as heat rises etc..so i think the ground floor etc will be a lot colder etc
maybe 1/2 way down stairs?
will down load PDF instructions tomorrow.
Old 20-10-2008   #5 (permalink)
mcmoby69
just read first post again! stat should be in hall. heat rises and will get to stat at top of house first. unscrew it from wall and put it on the wall with some blu tack in the hall first. see if it works. if it does fix it in that position.
Old 22-10-2008   #6 (permalink)
ajepo
View ajepo's Photo Album
Maybe the singnal isnt being recived because its out of range, you should read your manufactures instructions on its range.. I no the lower you go the falser the reading of temp, but maybe if TRVs are fitted upstairs it could help controll and balance the heating temp?
just my opinion pal..
Also you could think about moving the reciver to maybe the middle of the propperty, but this will need all the wireing extended from the boilers location and hiding or chaseing the wires, its your call pal
Jep
ajepo is offline   Reply With Quote
Old 22-10-2008   #7 (permalink)
dam
View dam's Photo Album
stands to reason , get the stat down low just off the hall to avoid any drafts.
dam is offline   Reply With Quote
Old 25-10-2008   #8 (permalink)
yammas
View yammas's Photo Album
Regards to wireless recievers, we fit Valliant boilers and the VRT360f programmable room stat... we installed the room stat in a area within a house with the receiver located in a boiler room....through 2 solid walls ..all works very well
Most stats should be located within a neutral point within the house,
we had a problem once we room stat located on wall of airing cupboard...
kept going off.... due to transfer of heat through partition wall!!
yammas is offline   Reply With Quote
one room hot rest cold LennieT Plumbing Forum 4 17-11-2008 11:15 PM
Hot tank stat plotnine Central Heating Forum 1 14-10-2008 10:19 PM
room stat brian_the_gas Central Heating Forum 2 10-09-2008 07:59 AM
