Old 17-10-2008   #1 (permalink)
hughs
View hughs's Photo Album
Default Separate pump in addition to the one included in the condensing boiler?
My main question is whether I need a separate pump in addition to the pump within the condensing boiler.
I am replacing a boiler. The previous boiler was the old open flue type and had two external pumps. The new boiler is a Vaillant EcoTec 630 plus system boiler. The boiler together with the hot water tank are situated in the garage. The boiler also feeds the hot water system to heat up three towel rails (i.e. they are heated whenever the hot water is switched on). There is an independent pump for the showers, which has a separate run to the house and back. The condensate from the boiler will be put into a soakaway adjacent to the garage wall. The pipe run from the beginning of the house and the boiler in the garage is approx 9 metres. The house has 4 bedrooms.
Almost all the engineers suggested that we needed a pump in addition to the pump included in the boiler and the shower pump. My chosen supplier does not believe that a separate pump is required. He states that the boiler pump will be sufficient to pump both the hot water and the central heating system to the house (quite apart from the shower pump which is independent). I am confused. What is the purpose of the additional pump? Is it required for the above system? What part of the system would it pump (i.e. central heating radiators, hot water etc). What difference would I notice if I do not have the additional pump installed?
Urgent advice would be much appreciated. Many thanks.
hughs is offline   Reply With Quote
Old 17-10-2008   #2 (permalink)
unguided1
View unguided1's Photo Album
Default Re: Separate pump in addition to the one included in the condensing boiler?
Hi Hughs
I'm a little confused here can you supply a pic because as I am reading this, is your second pump feeding the showers placed, next to your Hot water cylinder and feeding into it either somewhere near the top of the cylinder or into the cold feed if so as you have stated then this is a secondary return for the hot water system. or are you saying that you have three pumps in total. 2 on the heating circuit and another for the showers. If you have 2 pumps on the heating circuit how many zone valves do you have? Your house doesnt sound that big.
unguided1 is offline   Reply With Quote
Old 17-10-2008   #3 (permalink)
hughs
Quote:
Originally Posted by unguided1 View Post
Hi Hughs
Thank you Unguided.
To clarify (if I can!) there were three pumps in the old system One for the hot water, the second for the heating system and the third for the shower.
Unfortunately the system was dismantled yesterday as the boiler had packed up. I am told that in the previous system, one pump was for the central heating system and the other for the hot water. I could only switch on the central heating if the hot water came on at the same time. The water from the hot water taps did not gush out when opened. The shower pump is entirely separate - it has its own feed all the way to the house.
I do not believe I had any zone valves, noting my comments above.
Now (in the new system) there will be valve(s) to separate the hot water and central heating. I am told that is the reason we do not need the extra pump. The engineer has said that the pump within the condensing boiler will be sufficient to pump both the heating and hot water systems, including the run of 9 metres (or so) from where it is sited to the beginning of the house. The run (of pipes) within the house would be as for a normal 4 bedroom house.
Is this accurate (that I do not need an extra pump)?
Old 17-10-2008   #4 (permalink)
unguided1
He is right the old system sounds like a bit of a lash up to me
Old 21-10-2008   #5 (permalink)
hughs
Thanks Unguided for your help.
Old 30-10-2008   #6 (permalink)
Phoenix Heating
View Phoenix Heating's Photo Album
are u upgrading to a combination boiler?
or are u using a system boiler?
Phoenix Heating is offline   Reply With Quote
Old 03-11-2008   #7 (permalink)
CharterGAS
View CharterGAS's Photo Album
the 2 pump system was an old way of doing it and is probably still better than having stupid zone valves!!!
BUt yes you only need he one in the boiler providing the head of the pump is big enough relative to size of system
Old 18-11-2008   #8 (permalink)
hughs
Thanks Phoenix.
I am using a system boiler.
Thanks CharterGas.
Pump running and boiler fired up all the time Notebook Central Heating Forum 3 03-11-2008 07:44 AM
YPlan wiring help needed flying lee Central Heating Forum 2 13-09-2008 01:31 PM
