Results 1 to 11 of 11
Plumbing & Plumbers Forum - Main 24HE flame failure
Discuss Main 24HE flame failure in the Central Heating Forum at Plumbers Forums; Hi went to a Main 24 he today (very much a B rated baxi combi HE) Boiler works fine 50% of the time. There is a fault on CH & ...
    Jun 2009
    Devon
    25
    Default Main 24HE flame failure
    Boiler works fine 50% of the time. There is a fault on CH & DHW mode which is as follows;
    Pump runs, primary flow swith operates, fan runs at full speed but there is no atempt at igniton, then flame failure light comes on, will not reset, you have to turn selector swith on/off a couple of times. or;
    When the boiler is fired up in either CH or DHW mode the flame will cut out then straight away fire up again and carry on working.
    I have had this probem with the baxi 105he and it was the pcb, i keep a selection of pcbs in the van so tried it on this and it hasnt sorted it.
    Im thinking check min burner pressure, air pressure switch (unlikey as it does fire up most of the time) flame sensing electrode.
    Any iders?? Anybody come across this probem before??
    Will be going back to carryout more checks so will update
    Cheers!!
    Jun 2010
    Cumberland
    975
    Default Re: Main 24HE flame failure
    Try that air pressure switch. Had it a few times right on the edge of its pressure setting (tiny hole in diaphragm) just creeps off
    Jun 2009
    Devon
    25
    I see what you mean, just enough for the boiler to cut out but not enough for it to not work at all.
    I'll update and cheers for the reply!
    SUPER MODERATOR
    REDSAW's Avatar
    Jan 2009
    sherrif county
    9,084
    weve had 3 new pcb's on these boilers a few times now, try another.
    ¿ʞɹoʍ sɐƃ
    uɐɯ sɐƃ moderator
    gas man's Avatar
    maesteg,south wales
    13,315
    could be airswitch had a few go on the main,pcb tends to give the same fault but they are not weak boards
    GASMAN
    IMPOR
    Jun 2009
    Devon
    25
    Went back and replaced the air pressure switch- Sorted it!
    I noted in the manufactures instructions it says to take the fan out first in order to get to the air pressure switch (HE model) I just loosend off the side panel and got my hands in there, a lot quicker than taking the fan out!!
    Good diagnosis guys, and thanks for the replys!
    pls help. my baxi 24 he burner fails. cannot get it to start up. i am not a plumber unfortunately but would like to see if i can try to rectify the prob with your help
    uɐɯ sɐƃ moderator
    gas man's Avatar
    maesteg,south wales
    13,315
    Quote Originally Posted by martin1234 View Post
    check your condensate pipes not frozen if its a he model
    GASMAN
    IMPOR
    Oct 2010
    1,654
    a nice kettle of hot water on pipe should do it
    Quote Originally Posted by gas man View Post
    thanks for your reply. it fails intermittently! works then stops. it has been doing this for few weeks now
    thanks
    martin
    uɐɯ sɐƃ moderator
    gas man's Avatar
    maesteg,south wales
    13,315
    probable ap switch failing
    GASMAN
    IMPOR
  1. New connection from water main.
    By sparky in forum Plumbing Forum
    Last Post: 20-07-2010, 10:18 PM
  2. Main combi 24 he dhw problem
    By GrumpyOldGit in forum Central Heating Forum
    Last Post: 26-06-2010, 09:57 AM
  3. Rising main to cold water cistern in loft
    By Gareth in forum Plumbing Forum
    Last Post: 20-02-2010, 01:55 AM
  4. Potterton Profile 60e Main Burner cuts out
    By pickse in forum Central Heating Forum
    Last Post: 28-11-2009, 06:21 PM
  5. Trianco Eurostar 65 will not flame
    By etaf in forum Central Heating Forum
    Last Post: 24-12-2008, 04:39 PM
main combi 24 he flame failure
main 24 he flame failure
main combi 24 he air pressure switch
main 24 he
air pressure switch main 24 he
main 24he flame failure
main 24 he boiler manual
