Plumbing & Plumbers Forum - Vaillant ecotec plus 831 advise please
Discuss Vaillant ecotec plus 831 advise please in the Central Heating Forum at Plumbers Forums; Hi all, I am new to this forum, but I have a problem, and I have seen there are some knowledgeable people on here that maybe able to help. I ...
    Default Vaillant ecotec plus 831 advise please
    Hi all,
    I have a Vaillant ecotec plus 831 boiler, and I repeatedly get the F75 error code. I have been advised that the problem is the pressure sensor, and if I have the orange one it needs replacing to the new one which is black. I have managed to find out the partnumber for this, and have ordered one,and it has arrived.
    The problem I have is I have removed the sensor before to clean and at the time water came gushing out, despite me emptying the boiler or as I thought anyway. Could someone that has experience of changing or removing these advise me on how to stop the water coming out - (ie is this water coming from mains or is it coming from boiler, and if so what is the best way to stop it whilst I swap it over.
    Thanks in advance
    Plumbing Forum Contributor
    Sep 2008
    uk
    94
    Default Re: Vaillant ecotec plus 831 advise please
    its connected to central heating and requires draining down fully and maybe a black bag under part your changing to stop water going over boiler.
    F75 is normally a pump fault (normally blocked pump)
    Jun 2009
    753
    as plumbgod says its a pump fault,how olds the boiler,vaillant have modifed pumps on new 831,s ,they have found on the older models the pump cant cope if the water is dirty,i would cleanse system,replace pump,you cant just change pump head
    Aug 2010
    Hi, I was a Vaillant engineer for 21 years. I recently had the same problem on the same model. Through my contacts I was advised to change both the pump (wilo) for Grunfos AND the pressure sensor. It is also worth noting that the rubber pipes burst after a couple of years leading to a VERY expensive repair. They have a conversion kit for it that replaces the rubber pipes with copper ones @ about £50 EACH!!!
    May 2009
    7,303
    Were's all the Vaillant lovers now !!
    imho
    Aug 2010
    As regards the water coming out when you remove the sensor. Pump out the expansion vessel before removing the sensor. It wont stop ALL the water but will help big time if the vessel is empty of pressure. Mike.
  1. Vaillant ecoTec plus 637 'Kettling' noises
    By emailalantaylor in forum Central Heating Forum
    Last Post: 10-06-2010, 11:22 PM
  2. vaillant ecotec 831 combi pressure rise
    By newbie1 in forum Central Heating Forum
    Last Post: 05-04-2010, 03:30 PM
  3. Vaillant Ecotec 831 advice please
    By Bart in forum Central Heating Forum
    Last Post: 22-03-2010, 05:26 PM
  4. Honeywell CM921 and Vaillant EcoTEC
    By mattallen01 in forum Central Heating Forum
    Last Post: 29-12-2009, 04:44 PM
vaillant ecotec plus 831 fault code f75
vaillant ecotec plus f75
vaillant ecotec plus 831 f75 fault
vaillant ecotec plus 831 fault code 75
vaillant ecotec plus fault code f75
vaillant ecotec plus fault f75
vaillant ecotec plus f75 fault
