Whats this valve for?
I have a simple fully pumped CH and HW system. The flow from the pump connects the two zone valves from a tee connection. The controller allows for separate function of the zone valves so it is possible to have just hot water, just central heating, or both depending on timer settings.
I also have one gate valve whichh I can’t not see the reason for.
After the pump and before the tee to the zone valves there is a tee. This feeds to a gate valve that is just cracked open, the outlet connects to the downstream side of the HW water zone valve via another tee.
This valve is allowing the hot water to bypass the HW zone valve even when only CH is called for.
Any ideas why the corgie plumber who installed the system would have fitted it? Is it really necessary and how can I regulate the setting to prevent hot water heating when I don’t want it.
plotnine
